Flush fuel caps
vmenkal(at)mac.com
PostPosted: Thu Nov 27, 2008 5:34 pm    Post subject: Flush fuel caps Reply with quote
Seeking advice on flush fuel cap installation.
Planning to install ACS 10610 vented flush fuel caps on my 701 fuel
tanks to make the wings pretty (and hopefully avoid some of the
problems with the existing filler necks and caps). I was wondering
if anyone else has installed flush fuel caps and what treatment was
used for the skin - cap flange interface. Were the skins riveted
to the the fuel cap tank flange or where they left free to flap in the
breeze as the stock installation? Was the skin extended over the
flange right up to the cap or butted up to the flange. Any problems
with fit due to curvature of the skin and the distance from the skin
to the flange? Did it hurt when you cut off the existing filler neck?
And finally any thoughts on the best gasket material and fasteners to
use. Any pros and cons on cork vs standard fuel resistant gasket
goop?
Thanx Vic
Whitehorse Yukon
CH701 tail feathers complete covering wings
Brady
PostPosted: Fri Nov 28, 2008 12:14 pm    Post subject: Re: Flush fuel caps Reply with quote
Vic,
Here is a picture of the caps I put in my wings.
Is this what you had in mind?
 Filesize:  2.48 MB
 Viewed:  771 Time(s)
Brady McCormick
Poulsbo, WA
www.magnificentmachine.com
ricklach
PostPosted: Sat Nov 29, 2008 9:37 am    Post subject: Re: Flush fuel caps Reply with quote
Great job Brady, could you provide some more info about the installation. What type of caps and where did you get them? How do they attach to the fuel tank? How did you attach them to the skin? Anything you can provide would be of great help as I have wanted to make this mod for a while but just haven’t gotten there yet. So it looked like now is the time.
Rick
701Driver
N35 26.700, W118 16.743
Brady
PostPosted: Sat Nov 29, 2008 10:18 am    Post subject: Re: Flush fuel caps Reply with quote
Vic & Rick, Smile
The Caps are the same ones the 601 boys use. I got them from Aircraft spruce # 05-28666.
To get the flange to sit flush with the skins I had to adjust the angle of the threaded bung that is welded into the tank. Because I welded my own tanks and I knew I wanted flush caps from the out set, I just welded them in at the correct angle.
I don't think this would be an easy retro fit. Smile
To keep the skin tight to the flange I put a piece of soft foam (like a sponge) between the skin & the tank to evenly hold it up and then just screwed the cap flange down over it.
Clear as mud? Smile
Brady McCormick
Poulsbo, WA
craig(at)craigandjean.com
PostPosted: Sat Nov 29, 2008 10:32 am    Post subject: Flush fuel caps Reply with quote
So how do you vent your tanks? The caps on the 601XL are not vented but they
are on the 701. Did you add a vent when you built your tank?
-- Craig
PostPosted: Sat Nov 29, 2008 10:33 am    Post subject: Flush fuel caps Reply with quote
One 601XL builder (Patrick W.) used the foam sleeves you put around a beer
can to support the skin around the neck.
-- Craig
 Filesize:  100.42 KB
 Viewed:  630 Time(s)
Brady
PostPosted: Sat Nov 29, 2008 12:22 pm    Post subject: Re: Flush fuel caps Reply with quote
Ah! Very Happy
101 uses for the BEER COZY!
I love it!
But wait! Shocked
what if your beer gets warm!
Oh crap!
quick! i need another beer cozy! Laughing
The tanks are vented through the bottom like a Cessna tank.
the vent tube is cut at a 45* angle at the top and the bottom, it is positioned so that it is at the farthest forward and upper corner. It is welded to the bottom of the tank and the 45* angles face forward so as to provide positive pressure in flight.
I figured if gravity feed tanks on high wing aircraft have been vented like this for almost a hundred years or so it should be good enough for my 701 Smile
Brady McCormick
Poulsbo, WA
PostPosted: Sat Nov 29, 2008 12:29 pm    Post subject: Flush fuel caps Reply with quote
Intentionally or unintentionally you have duplicated the vents in the 601XL
tanks.
My only question about the beer can insulator is if the foam rubber
disintegrates in contact with fuel.
-- Craig
Brady
PostPosted: Sat Nov 29, 2008 1:54 pm    Post subject: Re: Flush fuel caps Reply with quote
Craig,
I had noticed that the 601 uses the same vents, in fact I wondered why the 701 wasn't designed that way initially?
I was familiar with the Cessna's' vents before I was aware the 601s were done that way. When I saw that the 601s were vented like that, that is when I noticed the flush caps.
Now I pay very close attention to the way things are done on the 601 so as not to over look any thing that may improve the 701.
I actually have the plans for a 601 as well and that may be my next project although the Cassutt has the potential to be a much faster airplane and may be the test bed I need to prove my products in a more extreme environment.
I had considered that the gas may melt the foam as well so I seated the flanges in a compound call 3M 5200 which (from what I understand) was developed by 3M for Boeing.
This stuff is common to boat builders and has the reputation for being very tenacious stuff.
I have used it extensively in the marine industry and I have seen it De laminate the best of composite layups on dis assembly.
there is a liquid anti adhesive that allows you to un-glue it but it is slow and expensive.
I have found that a hot putty knife is best used to cut the bond.
I have not seen how it reacts to long term exposure to gasoline but that's why we call it experimental. Smile
I plan on being very careful during fueling and promise not to spill much Smile
Brady McCormick
Poulsbo, WA
Curt.Thompson(at)verizon.
PostPosted: Sat Nov 29, 2008 8:34 pm    Post subject: Flush fuel caps Reply with quote
I'd use a sealed cap and vent the tank. There are messages in the archive
about fuel getting siphoned out of vented caps (unless they have the forward
facing vent tube brazed to the cap).
Curt
raymondj(at)frontiernet.n
PostPosted: Sat Nov 29, 2008 9:12 pm    Post subject: Flush fuel caps Reply with quote
Greetings,
I'm not familiar with the way Cessna vents their tanks. Can you refer
me to a diagram?
Raymond Julian
Kettle River, MN
"Hope for the best,
but prepare for the worst."
PostPosted: Sat Nov 29, 2008 9:22 pm    Post subject: Flush fuel caps Reply with quote
Raymond,
Here is a Cessna Tech Note on "Uneven Fuel Feeding in Single Engine
Cessna's":
http://www.moonflight.org/Documents/Fflow.pdf
It has a lot of info about the fuel system.
Curt
PostPosted: Sat Nov 29, 2008 10:16 pm    Post subject: Flush fuel caps Reply with quote
Curt,
Thanks for the reply. Lots of schematics and info. I'll put that one in
my library.
I'm still looking for a diagram for the physical setup of the vent. I
can't visualize the way it was described.
Raymond Julian
Kettle River, MN
"Hope for the best,
PostPosted: Sat Nov 29, 2008 10:36 pm    Post subject: Flush fuel caps Reply with quote
Here is a sketch of what I think Brady was writing about.
Curt
 Filesize:  108.06 KB
 Viewed:  617 Time(s)
Brady
PostPosted: Sun Nov 30, 2008 2:07 am    Post subject: Re: Flush fuel caps Reply with quote
That's it !
Exactly! Very Happy
Except the vent is as far forward in the tank as possible because they are taller in the front.
The low side of the fuel cap is a bit farther aft so you can never fill the tank all the way to the very top. so unless you had over full tanks and were in a severe nose down attitude fuel should not leak out the vent. (other than slosh)
Brady McCormick
Poulsbo, WA
PostPosted: Sun Nov 30, 2008 3:53 am    Post subject: Flush fuel caps Reply with quote
Thank you very much, now I understand. Looks like a good simple system.
Thanks again Curt and Brady.
Raymond Julian
Kettle River, MN
"Hope for the best,
ricklach
PostPosted: Sun Nov 30, 2008 5:43 pm    Post subject: Re: Flush fuel caps Reply with quote
One last question Brady. What size tube did you use in your tanks for the vent tube? I guess two question, what size material did you make your tanks out of. I will be making my tanks this winter and the material used in the factory tanks seams so thin.
Rick
701Driver
