atrent7(at)cogeco.ca Guest
Posted: Sat Apr 08, 2006 6:17 am Post subject: 601 floats |
Has anyone installed floats on a 601 taildragger? I am considering
doing so and wondered about how one would attach same.
Trigear is attached to the undercarriage attach points, this won't work
on a tail dragger. At least I can't visualize it. Open to any reasonable
explainations.
alex
gordo(at)xplornet.com Guest
Posted: Tue Apr 11, 2006 6:21 pm Post subject: 601 floats |
Alex, Grove Aircraft makes a spring gear for the ch601, I dont know alot about the taildragger but you may be able to install the spring gear which would provide you a better platform to mount the floats. If you wantamphibs the latest floats from czech have 4 wheel versions eliminating the need to install the nose wheel.Just a thought ... www.groveaircraft.com C-FXZI on amphibs
Gord O'Donnell
