Heaters
g-iani(at)ntlworld.com
PostPosted: Sat Nov 22, 2008 8:13 am    Post subject: Heaters Reply with quote
Bud
I have looked at your heater and it is in principal the same as mine and many others. That is taking the warm air off the rear of the water radiator. Mine is fitted but not operational (fire wall phenolic is bolted over the outlets of the SCAT tubes)
The reason for this is that Francis Donaldson (LAA) insists on a fire stop valve at the point were the tube passes through the fire wall. One builder, Mike Parkin, has made up some very expensive petal valves to achieve this. See attached. I am still looking for a cheaper and simpler solution to these valves.
Obviously US regulation is not the same as ours. What are your thoughts on a) the need for fire stop valves and b) a simpler cheaper way of achieving a fire stop?
Ian Rickard G-IANI XS Trigear, 200 hours
Europa Club Mods Rep (Trigear)
e-mail mods(at)europaclub.org.uk
or direct g-iani(at)ntlworld.com
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of ALAN YERLY
Sent: 21 November 2008 23:26
Subject: Re: New Europa Website
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Jeff,
Working on that with better access for fuel tank, controls, mods or repairs. The cockpit module is heavy and requires a lot of help to get it in right and it is very time consuming to build for the novice, and for the company to construct.
Keep the ideas coming.
Go to my website and download the heater. One inch tubes is all you need really to keep the plane warm.
Bud
Custom Flight Creations
 Filesize:  194.12 KB
 Viewed:  249 Time(s)
rob(at)hyperion-ef.com
PostPosted: Sat Nov 22, 2008 1:17 pm    Post subject: Heaters Reply with quote
Here’s my method of maintaining firewall integrity. The brass colored item hooked between the two tabs is a fusible link (McMaster-Carr part number 1147A14) with a melting point of 100 deg C. The stainless steel flap employs a hinge with a spring to snap it shut once the fusible link melts. This takes more space than Mike’s scheme but it is an inexpensive solution.
Best regards,
Rob Housman
Irvine, CA
Europa XS Tri-Gear
A070
Airframe complete
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of G-IANI
Sent: Saturday, November 22, 2008 8:10 AM
Subject: RE: Heaters
Bud
Jeff,
Bud
 Filesize:  345.26 KB
 Viewed:  261 Time(s)
mikenjulie.parkin(at)btin
PostPosted: Sun Nov 23, 2008 1:56 am    Post subject: Heaters Reply with quote
Hi Guys,
I note your comments on the heater system. I have to say that my experience with the system has shown it is not as effective as you might imagine. The problem is that it works fine in the climb when the temperatures are up, but in the cruise, my 914 will cool right down and then the heater is ineffective.
The cooling system on G-JULZ is just too effective in the cruise and it concerns me that the engine is running for lengthy periods at temperatures well below 100degC. I have a modification in progress to introduce a cowl flap in the cooling air exit in an effort to control the engine temperatures. If it is effective I am also developing a micro-processor temperature control system to make the whole system automatic.
If this mod works then, the heater will hopefully become more efficient.
Mike
budyerly(at)msn.com
PostPosted: Sun Nov 23, 2008 11:16 am    Post subject: Heaters Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> I use an expensive and fully lockable cable which holds the flapper shut because I fear the same problem. That shuts off the fire inlet at the duct. I draw the air from a low risk fire area, but not a perfect solution.
If I had regs requiring a stop valve, I would make it from stainless as a box with a flapper in it. Aircraft Spruce has a heater valve which I would use as a guide. Theirs is made of aluminum. Let's face it, if the aluminum melts because of a fire, you're in serious do do.
Bud
pete(at)lawless.info
PostPosted: Sun Nov 23, 2008 11:52 am    Post subject: Heaters Reply with quote
Bud
Spruce supply a stainless valve as well.
Pete
PostPosted: Mon Nov 24, 2008 2:08 am    Post subject: Heaters Reply with quote
Bud
Thanks for the comments, My thoughts entirely regarding aluminium melting
