AZFlyer
Posted: Sun Nov 16, 2008 7:26 pm Post subject: Gasolator and Fuel pump location |
Has anybody installed their gasolator and/or electric fuel pump on fwd side of firewall?
In one of Bingelis' how-to books he comments that most often this is where those are installed; but the materials with the 601XL and many builders feel it necessary to put a big hole in floor of the cockpit and plumb the gasolator in there.
Would like to hear from some of you with experience in this area...
Mike
_________________ Mike Miller @ millrml@aol.com
601 XL-B, 3300, Dynon
Remember, "the second mouse gets the cheese"! |
jmaynard
Joined: 27 Feb 2008 Posts: 394 Location: Fairmont, MN (FRM)
Posted: Sun Nov 16, 2008 7:36 pm Post subject: Gasolator and Fuel pump location |
On Sun, Nov 16, 2008 at 07:26:08PM -0800, AZFlyer wrote:
| Quote: | Has anybody installed their gasolator and/or electric fuel pump on fwd
side of firewall?
AMD mounts the electric fuel pump on the forward side of the firewall, and
the gascolator a little ways aft of it. (I think. It's in the center of the
fuselage, and you have to get under and behind the leading edge to get to
it.)
Jay Maynard, K5ZC, PP-ASEL http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
Fairmont, MN (KFRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml
_________________ Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC |
psm(at)att.net Guest
Posted: Sun Nov 16, 2008 7:54 pm Post subject: Gasolator and Fuel pump location |
I put the fuel pump on the firewall, but the gascolator on the cabin
floor as indicated on the drawings.
The gascolator needs to be at the lowest point of the fuel system,
and I don't think you can do that forward of the firewall.
Paul
XL getting close
Gig Giacona
Posted: Mon Nov 17, 2008 7:58 am Post subject: Re: Gasolator and Fuel pump location |
| psm(at)att.net wrote: | I put the fuel pump on the firewall, but the gascolator on the cabin
Well you can just not with the Zenith designed fuel system. The fuel system for the WW Corvair install has two pumps and the gasolator forward of the firewall here is a photo. And yes the gasolator is at the lowest point.
Here's a photo.
16.43 KB |
760 Time(s) |
601XL Under Construction
bryanmmartin
Posted: Mon Nov 17, 2008 4:01 pm Post subject: Gasolator and Fuel pump location |
As long as your fuel lines slope downhill all the way to the
gascolator and then slope uphill to the engine, the gascolator can go
anywhere you want it. The gascolator should be at the low point of the
fuel system or it can't do as good a job of trapping any water passing
through the system.
On Nov 16, 2008, at 10:26 PM, AZFlyer wrote:
Bryan Martin
CH 601 XL
Builder No: 64003
_________________ --
Bryan Martin
do not archive. |
naumuk(at)alltel.net Guest
Posted: Mon Nov 17, 2008 5:53 pm Post subject: Gasolator and Fuel pump location |
Mike-
Possibly, yes. Corvairs use a setup similar to the attached pictures for
HDSs. The main idea is to keep the primary ignition components cool via a
box fed by a rear engine baffle mounted SCAT tube.
I'm waiting the on components to finish my installation, which is a
direct rip-off of proven projects. I'll post pictures of the completed
effort if you'd like.
Bill
35.1 KB |
715 Time(s) |
48.53 KB |
755 Time(s) |
Posted: Tue Nov 18, 2008 3:27 pm Post subject: Gasolator and Fuel pump location |
Mike-
Check out the archives- there are many 601 builders with primary
electric/plumbing on the engine side of the firewall.
do not archive.
Bill
