Troy Maynor
Posted: Sun Nov 16, 2008 6:12 pm Post subject: Tachometer Question |
Hi Folks,
I have a Rotax 912S in a Europa I have been building. I have a Mitchell
tach. installed and also an Audio Flight Avionics
AV-10 digital electronic engine monitor. I want to monitor the rpm on both
of these at the same time. Can anyone tell me what precautions I need to
take in connecting these in parallel? I'm not very electronic savy, but I
can understand some of the terms and parts one might use. Any thoughts?
Troy Maynor
N120EU Europa Monowheel Classic
Left to finish:
Seats, engine install underway, some wiring.
Weaverville, NC USA
winmail.dat |
1.8 KB |
203 Time(s) |
nuckolls.bob(at)cox.net Guest
Posted: Mon Nov 17, 2008 6:04 am Post subject: Tachometer Question |
At 08:59 PM 11/16/2008 -0500, you wrote:
| Quote: | Hi Folks,
I wish there were a simple answer. There are tachometers, and then
there are tachometers. MOST were originally crafted to interpret the
frequency (read rpm) information from magneto p-leads . . . the most
gawd awful 'signal' in an airplane.
Over the years, variations popped up including tachs that looked at
the AC widing of a Rotax engine, hall effect devices that read
the magnetic field spinning inside a magneto, crankshaft or tach
drive transducers, etc.
Each of these variants had 'signal' qualities that might
make the indicators incompatible with each other when driven
by a single signal source.
You need to know what the two indicators expect in the way
of an RPM sensing signal. Given that you're flying a Rotax,
it seems likely that the only choices you may have for this
engine is to read the AC voltage from the alternator winding
or some sort of add-on crankshaft sensor.
Given that most tachometer folks expect to read p-leads,
it may be that your engine will require some sort of signal
conditioner to make your existing tach indicators function.
Further, it may need to be a dual-output signal conditioner
that accommodates both tachs.
