rparigor(at)SUFFOLK.LIB.N Guest
Posted: Mon Nov 17, 2008 8:02 pm Post subject: What wire to use for pitch servo |
I need to wire my Ray Allen servo on my Europa. I think it's a T3 servo,
has 5 wires.
I don't mind working with very small wires. Will install a connector at
servo. Will run servo wiring on port side, and antennas on starboard.
What suggestions on wire to use?
Some options:
****Ray Allen sells 5 color coded 26 gauge that is not twisted:
WC2 ... 5 WIRE TEFLONŽ INSTALLATION CABLE
We highly recommend using this wire cable for Ray Allen trim
installations. It consists of 5 separate color coded, 26 gauge, 19 strand,
silver coated, DuPont FEP TeflonŽ insulated wires inside a tough, all
TeflonŽ sheathing. This wire cable will easily last the lifetime of your
airframe. The cable is .140 inch (3.5 mm) in diameter.
****Stein Air sells 7 conductor twisted tefzel servo wire, consisting of 5
of 22 gauge and 2 of 20 gauge.
Can remove 2 of the 20 and have 5 of 22 left, or remove 2 of the 22 and
have 2 of 20 and 3 of 22 left
****Aircraft Spruce sells 24 gauge and 22 gauge tefzel wire.
Options:
5 of 24
3 of 24 and 2 of 22
Twist or not twist?
Thanking you in advance.
Ron Parigoris
