Sam
Posted: Mon Nov 17, 2008 4:12 pm Post subject: Soldering fat wires |
I just started attempting to solder terminals onto several 4awg wires. I'm using welding cable and one of those little butane torches.
I am attempting to use the techniques n Bob's article. However, when I apply the solder, it seems to wick along the cable, up to two inches past the terminal. It seems to run on the inside, without saturating the outside of the butt end.
The second time I tried it I was more careful to apply the solder around the perimeter of the wire, but still had the same result.
Is this normal, or is it just me?
Sam Hoskins
www.samhoskins.blogspot.com
_________________ Sam Hoskins
www.samhoskins.blogspot.com |
Michael Wynn
Joined: 10 Jan 2006 Posts: 148 Location: San Ramon, CA
Posted: Mon Nov 17, 2008 5:57 pm Post subject: Soldering fat wires |
Hi Sam,
I found a technique that works pretty well. Several companies have little solder and flux slugs that fit right down into the terminal. Then, you heat the terminal until the solder melts, push in the wire and keep heating until you have good solder flow. Let it cool, apply the heat shrink to the outside and there you are.
Michael Wynn
In a message dated 11/17/2008 4:15:48 P.M. Pacific Standard Time, sam.hoskins(at)gmail.com writes:
| Quote: | I just started attempting to solder terminals onto several 4awg wires. I'm using welding cable and one of those little butane torches.
Sam Hoskins
://www.matronics.com/contribution">http://www.matronics.com/contribution
st href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List
.matronics.com/">http://forums.matronics.com
?redir=http://toolbar.aol.com/moviefone/download.html?ncid=emlcntusdown00000001">Get the Moviefone Toolbar. Showtimes, theaters, movie news & more!
_________________ Michael Wynn
RV 8
San Ramon, CA |
nuckolls.bob(at)cox.net Guest
Posted: Tue Nov 18, 2008 6:24 am Post subject: Soldering fat wires |
Sounds like you're using way too much heat. See
if you can put your hands on a "micro torch"
of some variety.
http://aeroelectric.com/Pictures/Tools/Soldering/Gas_Tools/
Alternatively, turn your pipe-blaster propane
shop torch down to the smallest possible stable flame.
The inner blue cone should be about 1/4" long
max.
The wire strands inside the terminal need to be
TIGHT. Heat conducts across strands by virtue of
(1) contact and (2) immersion in molten solder.
Make sure the strands are well-wedged to improve
upon condition (1) so that condition (2) progresses
nicely as well.
Start by heating the back side of the terminal flag
and touch solder to the corner between the front
side of the flag and the cut ends of the wire. As
soon as the solder melts, it will begin to pick up
the wire strands. Walk around the terminal barrel
with the heat while feeding solder into the strands
adjacent to the inside surface of the barrel. The
heat in the joint will be climbing all the time
and by the time you get all around the barrel, you
will see solder wicking into the strands pretty much
all around. Feed a little more solder into the stranding
until all the ends are captured. If you see ANY solder
at the other end of the barrel, you've gotten it too
hot and/or put in too much solder.
From the time the solder first flows until the joint
is done is less than one minute. The longer you take,
the hotter things get, the less likely it is that
you can maintain control over the flow of solder.
( -Thomas Paine 1776- )
Sam
Posted: Tue Nov 18, 2008 7:24 am Post subject: Soldering fat wires |
Actually, I am already using a Bernzomatic micro torch. I'll heed your
advice by wedging it tighter and turning the heat down a bit.
Sam
On Tue, Nov 18, 2008 at 8:23 AM, Robert L. Nuckolls, III <nuckolls.bob(at)cox.net (nuckolls.bob(at)cox.net)> wrote:
[quote]--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net (nuckolls.bob(at)cox.net)>
of some variety.
max.
nicely as well.
Sam
Posted: Tue Nov 18, 2008 4:25 pm Post subject: Soldering fat wires |
I gave it another try today and really packed them tight. It worked a lot
better.
Great advice, Bob. Thanks for all your help.
Sam
of some variety.
max.
nicely as well.
