Allen Fulmer
Joined: 10 Jan 2006 Posts: 79 Location: Alexander City, AL
Posted: Wed Nov 12, 2008 7:46 pm Post subject: Z19RB Fat wire protection, etc. |
Okay Bob,
Airplane and configuration:
RV7 w/Eggenfellner Subaru H6 up front.
2 PC625 batteries in the very back of fuselage wired per Z19RB.
Fat wire (#4 CCA from Eric Jones) runs from battery contactors to a firewall
"pass thru stud" (West Marine). Firewall side of the stud has 2 connectors:
one to an ANL on the way to a 75A IR alternator (supplied with engine
package); another to the starter solenoid mounted as part of geared starter.
I think this is all in accordance with Z19RB architecture.
My question concerns the cockpit side of this "pass through stud". Could
you please reassure me that I am correct in planning a #6 wire from that
same stud (as the fat wire is connected to) to the MAIN POWER DISTRIBUTION
BUS (approximately 42 inches "as the wire goes") withOUT any fuse/breaker
protection?
Your picture:
http://www.aeroelectric.com/Pictures/Wiring_Technique/A36_Firewall_B.jpg
(cert. plane of course) shows a bunch of ANL's to avionics, etc., but in the
OBAM world I guess we do not need to imitate that kind of installation?
And could you also point me to the reference in AEC that speaks to the lack
of a need for ANL protection of the fat wire at the batteries? I think I
have read that ANL's are not needed by the batteries but can not remember
where I read that.
Thanks for all you do, Bob.
Allen Fulmer
RV7 Wiring/Plumbing
Eggenfellner Subaru E6Ti on firewall
N808AF reserved
Alexander City, AL
256-329-2001
_________________ RV7 QB Fuselage
Eggenfellner H6 on orde
N808AF reserved
Alexander City, AL |
nuckolls.bob(at)cox.net Guest
Posted: Thu Nov 13, 2008 4:03 am Post subject: Z19RB Fat wire protection, etc. |
At 09:44 PM 11/12/2008 -0600, you wrote:
Okay Bob,
protection?
That's correct.
I've never paid much attention to the fuse-patch on
the A36. Just pulled up the wiring diagrams. That airplane
has a variety of busses on the left cabin wall (c/b panel)
pilots switch panel (switch breakers), copilots switch
panel (miniature push-pull breakers), two alternators, etc.
This is a mechanically busy architecture that I hope will
never be implemented in an RV! The designers no doubt found
it necessary to worry about failure modes grown out of
complexity.
| Quote: | And could you also point me to the reference in AEC that speaks to the lack
where I read that.
It's a convention that has been with us for a long
time. Fat-wire feeders in small aircraft have never
benefited from circuit protection due to the nature
of the exceedingly rare, soft faults these wires
experience. By "soft fault" I'm referring to a condition
that will NOT product the hundreds of amps in current
flow necessary to open an ANL or similar device.
I've seen soft faults that parted elevator control
cables while never causing a light to flicker, no
smoke or bad smells, yet the feeder in question was
protected by a 40A breaker in a 28v aircraft! These
tend to be very high, total energy events delivered
in small packets over long periods of time. The FAA
acknowledges this in the crafting of FAR 23.1357 which
I quote . . .
Sec. 23.1357 Circuit protective devices.
(a) Protective devices, such as fuses or circuit breakers, must be
installed in all electrical circuits other than--
(1) Main circuits of starter motors used during starting only; and
(2) Circuits in which no hazard is presented by their omission.
(b) A protective device for a circuit essential to flight safety may not be
used to protect any other circuit.
(c) Each resettable circuit protective device ("trip free" device in which
the tripping mechanism cannot be overridden by the operating control) must be
designed so that--
(1) A manual operation is required to restore service after tripping; and
(2) If an overload or circuit fault exists, the device will open the
circuit regardless of the position of the operating control.
(d) If the ability to reset a circuit breaker or replace a fuse is
essential to safety in flight, that circuit breaker or fuse must be so
located and identified that it can be readily reset or replaced in flight.
(e) For fuses identified as replaceable in flight--
(1) There must be one spare of each rating or 50 percent spare fuses of
each rating, whichever is greater; and
(2) The spare fuse(s) must be readily accessible to any required pilot.
For the purposes of this discussion, paragraphs (a)(1) and (a)(2)
apply. I might point out also that our implementation of fuse-blocks
in a failure tolerant system design also meets the spirit and
intent of the rest of 23.1357 as well. If your system is failure
tolerant, then there are no single systems "critical" to safe
operations and termination of flight. If your fuse panels are
not accessible to the crew, then no spares need be carried
aboard the aircraft.
| Quote: | Thanks for all you do, Bob.
You're most welcome sir.
