Re-clocking the prop
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List
Im7shannon(at)aol.com
PostPosted: Tue Nov 11, 2008 3:54 pm    Post subject: Re-clocking the prop Reply with quote
Back in April 07 Michael Stewart posted some good info about reclocking the 2-blade Hartzell on an IO540 to reduce vibration. Now that my plane has 60 hours on it and I have fixed all the little first few flights squaks, I am now focusing on the vibration issue. I did not notice it much in the first few hours because I kept the RPMs up around 2350 but the more I play around with low power/RPM settings the more I feel it.
So I am wondering if anyone else has tried this since Michael showed us it worked, and Michael if you are reading this, I tried the link to your webpage from the 4/07 posting and it did not work, do you have a new web address?
Kevin Shannon
HR !!
N450KS
AOL Search: Your one stop for directions, recipes and all other Holiday needs. [url=http://pr.atwola.com/promoclk/100000075x1212792382x1200798498/aol?redir=http://searchblog.aol.com/2008/11/04/happy-holidays-from-aol-search/?ncid=emlcntussear00000001 ]Search Now[/url].
- The Matronics Rocket-List Email Forum -
http://www.matronics.com/Navigator?Rocket-List
kahuna
PostPosted: Wed Nov 12, 2008 8:14 am    Post subject: Re-clocking the prop Reply with quote
Hey Kevin,
Yes Im listening.
Been moving servers at the house to a new location today. It was down this morning.
Its up but a bit slow this morning due to other issues Im working.
SHould be up mostly today, then back up to complete snufff tomorrow.
Prop clocking and all the vib data here.
http://mstewart.net/super8/index.htm
Hollor if you have any questions.
I have done more prop testing in the past 2 years than I care to admit:)
Super 8 is going strong. Over 800 hours on her now. If I just had a few more knots:)
See ya
Mike
[img]cid:1__=08BBFE6CDFCB49D08f9e8a93df938(at)us.ibm.com[/img]Im7shannon---11/11/2008 07:03:20 PM---Back in April 07 Michael Stewart posted some good info about reclocking the 2-blade Hartzell on an IO540 to reduce vibration. N
[img]cid:3__=08BBFE6CDFCB49D08f9e8a93df938(at)us.ibm.com[/img]
To
rocket-list(at)matronics.com [img]cid:3__=08BBFE6CDFCB49D08f9e8a93df938(at)us.ibm.com[/img]
cc
Subject
Re-clocking the prop [img]cid:3__=08BBFE6CDFCB49D08f9e8a93df938(at)us.ibm.com[/img][img]cid:3__=08BBFE6CDFCB49D08f9e8a93df938(at)us.ibm.com[/img]
Kevin Shannon
HR !!
N450KS
AOL Search: Your one stop for directions, recipes and all other Holiday needx1200798498/aol?redir=http://searchblog.aol.com/2008/11/04/happy-holidays-from-aol-search/?ncid=emlcntussear00000001">Search Now.
ion">[b]http://www.matronics.com/contribution
?Rocket-List">[b]http://www.matronics.com/Navigator?Rocket-List
u>http://forums.matronics.com[/u]
 Filesize:  105 Bytes
 Viewed:  8209 Time(s)
 Filesize:  1.23 KB
 Viewed:  8210 Time(s)
 Filesize:  45 Bytes
fairlea(at)amtelecom.net
PostPosted: Wed Nov 12, 2008 8:18 am    Post subject: Re-clocking the prop Reply with quote
I purchased the new Hartzell two blade BA. It does not need any special clocking and it is as smooth as the three blade MT that it replaced. I had it dynamically balanced at the Hartzell shop when I picked it up. It is an 80 inch prop, looks good and is quite a bit faster, at full power, than the MT.
Tom Martin
From: owner-rocket-list-server(at)matronics.com [mailto:owner-rocket-list-server(at)matronics.com] On Behalf Of Michael W Stewart
Sent: November 12, 2008 11:14 AM
To: rocket-list(at)matronics.com
Subject: Re: Rocket-List: Re-clocking the prop
Hey Kevin,
Yes Im listening.
See ya
Mike
[img]cid:image001.gif(at)01C944B8.0EC4A790[/img]Im7shannon---11/11/2008 07:03:20 PM---Back in April 07 Michael Stewart posted some good info about reclocking the 2-blade Hartzell on an IO540 to reduce vibration. N
Sent by: owner-rocket-list-server(at)matronics.com
11/11/2008 06:53 PM
Please respond to
To
cc
Subject
Kevin Shannon
HR !!
N450KS
ion">http://www.matronics.com/contribution
?Rocket-List">http://www.matronics.com/Navigator?Rocket-List
Checked by AVG.
Checked by AVG.
 Filesize:  105 Bytes
 Viewed:  8208 Time(s)
 Filesize:  73 Bytes
 Viewed:  8207 Time(s)
 Filesize:  73 Bytes
James Baldwin
PostPosted: Wed Nov 12, 2008 9:28 am    Post subject: Re-clocking the prop Reply with quote
Hi Tom,
What does the Hartzell two blade weigh? Thanks. JBB
From: owner-rocket-list-server(at)matronics.com [mailto:owner-rocket-list-server(at)matronics.com] On Behalf Of Tom Martin
Sent: Wednesday, November 12, 2008 8:16 AM
Subject: RE: Rocket-List: Re-clocking the prop
Tom Martin
Hey Kevin,
Yes Im listening.
See ya
Mike
[img]cid:image001.gif(at)01C944A8.DCEC2DB0[/img]Im7shannon---11/11/2008 07:03:20 PM---Back in April 07 Michael Stewart posted some good info about reclocking the 2-blade Hartzell on an IO540 to reduce vibration. N
11/11/2008 06:53 PM
Please respond to
To
cc
Subject
Kevin Shannon
HR !!
N450KS
Checked by AVG.
Checked by AVG.
 Filesize:  105 Bytes
 Filesize:  73 Bytes
 Filesize:  73 Bytes
PostPosted: Wed Nov 12, 2008 12:20 pm    Post subject: Re-clocking the prop Reply with quote
68 pounds, three pounds heavier than the non counterweighted prop and 6 pounds lighter than the counterweighted version. I forget the weight of the old paddle blade but this one should be similar.
Tom Martin.
From: owner-rocket-list-server(at)matronics.com [mailto:owner-rocket-list-server(at)matronics.com] On Behalf Of James Baldwin
Sent: November 12, 2008 12:27 PM
Hi Tom,
Tom Martin
Hey Kevin,
Yes Im listening.
See ya
Mike
[img]cid:image001.gif(at)01C944D9.A55C2040[/img]Im7shannon---11/11/2008 07:03:20 PM---Back in April 07 Michael Stewart posted some good info about reclocking the 2-blade Hartzell on an IO540 to reduce vibration. N
11/11/2008 06:53 PM
Please respond to
To
cc
Subject
Kevin Shannon
HR !!
N450KS
Checked by AVG.
Checked by AVG.
Checked by AVG.
Checked by AVG.
 Filesize:  105 Bytes
 Filesize:  73 Bytes
 Filesize:  73 Bytes
smokyray(at)rocketmail.co
PostPosted: Wed Nov 12, 2008 12:56 pm    Post subject: Re-clocking the prop Reply with quote
Tom,
Here is the data Les Doud at Hartzell ran on the 8068D BA blades on my HR2. I plan on buying one someday soon. Could you send me your photos to smokyray(at)rocketmail.com?
Smokey
HR2
Rob,
I ran two conditions:
1. 8500 ft, 192 KTAS (195 mph indicated), 200 Hp (at) 2400 RPM
2. S.L., 204 KTAS (235 mph), 285 Hp (at) 2700 RPM
The 8068:
1. 88.4%, 300 lbs.
2. 88.3%, 402 lbs
The 8068D:
1. 88.9%, 302 lbs.
2. 89.1%, 405 lbs.
Although the efficiency/thrust numbers are close, the blade loading is more optimal on the "D" twist which should have favorable installation effects (lower drag). To my knowledge nobody has tested an 8475J-4 or an 8475D-4 two blade back-to-back with an 8068D. The only testing I'm aware of is what I did with Paul Seigel on his F-1 and what Tom Martin did, both started with an MT prop.
The other (hopeful) benefit of this blade is I married it with the DHC- hub indexing to lower cabin vibration levels. Based on Paul and Tom's feedback it appears the new prop is on par with the MT for smoothness. Again, only someone testing back-to-back with an HC- prop will be able to qualify the improvement relative to what we've been selling.
Respectfully,
Les Doud
Propeller Integration Engineer
Hartzell Propeller Inc.
Phone: 937-778-4262
Fax: 937-778-4321
--- On Wed, 11/12/08, Tom Martin <fairlea(at)amtelecom.net> wrote:
Subject: RE: Re-clocking the prop
Date: Wednesday, November 12, 2008, 12:17 PM
Tom Martin.
Hi Tom,
Tom Martin
Hey Kevin,
Yes Im listening.
See ya
Mike
[img]cid:1.2376157532(at)web110213.mail.gq1.yahoo.com[/img]Im7shannon---11/11/2008 07:03:20 PM---Back in April 07 Michael Stewart posted some good info about reclocking the 2-blade Hartzell on an IO540 to reduce vibration. N
11/11/2008 06:53 PM
Please respond to
[img]cid:2.2376157533(at)web110213.mail.gq1.yahoo.com[/img]
To
[img]cid:3.2376157533(at)web110213.mail.gq1.yahoo.com[/img]
cc
Subject
Kevin Shannon
HR !!
N450KS
Checked by AVG.
Checked by AVG.
Checked by AVG.
Checked by AVG.
 Filesize:  105 Bytes
 Filesize:  73 Bytes
 Filesize:  73 Bytes
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List All times are GMT - 8 Hours
