[Probable Spam] Re: Dual Bing Carbs Hookup
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Stratus-List
larry(at)macsmachine.com
PostPosted: Tue Nov 11, 2008 2:47 pm    Post subject: [Probable Spam] Re: Dual Bing Carbs Hookup Reply with quote
Trey,
I didn't replace the throttle arms, only removed the springs that kept a
force on them. I did remove the throttle arm
on the carb opposite of the push pull linked carb.
http://www.macsmachine.com/images/controllinkages/full/abinghardcablelink.gif
The cable attachment at the arms end rotates in the arm and allows the
music wire to push and pull without
binding.
http://www.macsmachine.com/images/controllinkages/full/abingrtlinkopen.gif
http://www.macsmachine.com/images/controllinkages/full/abingleftlink.gif
Larry McFarland
Trey Moran wrote:
<nail13zg(at)centurytel.net>
Hi Larry,
Thanks for the individual pics with explanations. That really helps.
One last question (I hope). Where did you get the throttle arm that
allows you to push for power? Right now, my throttle arms are spring
loaded to the idle position (based on fact that the spring holds the
arm against the idle set screw) and any direct cable connection to the
arm is a "pull to add power" connection.
Trey
- The Matronics Stratus-List Email Forum -
http://www.matronics.com/Navigator?Stratus-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Stratus-List All times are GMT - 8 Hours
