akflyer
Posted: Mon Nov 10, 2008 10:21 pm Post subject: N61PW takes to the skys again |
After a few years under a tarp, I rescued N61PW from going to the dump. 2 years later, after an extensive rebuild and lots of real bad swear words I got to give her the first flight today. She came out a portly 581 pounds even after I removed a bunch of crap the original builder had installed... but I think I added back all but 3 pounds by using medium weight fabric and putting on 24" aircraft tires (heavy buggers). It came out with a CG of 11.8". I will be putting a survival pack together and putting it as far aft as I can in the extended bagage area (goes back to the front of the vert. stab.)
All in all it has been alot of fun, but more work that if I had bought a new kit... Today made all the cuts and burns worth it when she broke ground and did not have any bad habits.
140.86 KB |
573 Time(s) |
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
akflyer
Posted: Tue Nov 11, 2008 10:50 pm Post subject: Re: N61PW takes to the skys again |
link to the first flight vid.
http://www.youtube.com/watch?v=sUCPXGh0gNI
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Wed Nov 12, 2008 6:35 am Post subject: Re: N61PW takes to the skys again |
Leonard, very nice looking bush plane. Do you hand prop to start it?
_________________ Tom Jones
Classic IV
Ellensburg, WA |
akflyer
Posted: Wed Nov 12, 2008 8:29 am Post subject: Re: N61PW takes to the skys again |
No sir, I have the clutch... I am trying to figure out a way to be able to lock it up in the event of a battery failure out in the boonies... I have to pull it apart next time home and see if I can drill and tap the clutch so set screws can be run in to prop it in the event that I lose a starter or battery.
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
