Phil.Perry(at)netapp.com Guest
Posted: Mon Nov 10, 2008 7:06 pm Post subject: HS Attachment Bar Clearance |
Hi,
I'm currently fitting the longerons inside the tailcone.
On page 10-6 Step 1, we're asked to remove an area of material for clearance of the HS attachment bars.
Upon fitting, I'm finding that the HS attachment bars are touching the longerons.
1) Is this acceptable? I'm guessing not.
2) I've continued to remove material from the longeron and right now I'm pushing 15/32 of removed material when the plans called for 11/32. In order to get the HS attachment bars to easily clear, I'm guessing I'll have to removed another 2 or 3/32. Is that a problem or should I just start over with a new longeron?
Here are links to the photos.
http://i141.photobucket.com/albums/r51/philperry9/RV-10%20Build/DSC_3395.jpg
http://i141.photobucket.com/albums/r51/philperry9/RV-10%20Build/DSC_3396.jpg
http://i141.photobucket.com/albums/r51/philperry9/RV-10%20Build/DSC_3397.jpg
Phil
