CH701 nose wheel bearing
gus
PostPosted: Mon Nov 10, 2008 4:47 pm    Post subject: CH701 nose wheel bearing Reply with quote
I am looking for ideas to improve the bearing on my nose wheel strut. I have many versions , what works best?
Brady
PostPosted: Tue Nov 11, 2008 9:24 am    Post subject: Re: CH701 nose wheel bearing Reply with quote
Gus,
What is wrong with the design in the plans?
Brady McCormick
Poulsbo, WA
www.magnificentmachine.com
gus
PostPosted: Tue Nov 11, 2008 12:46 pm    Post subject: Re: CH701 nose wheel bearing Reply with quote
I am interested in learning what others have done with the metal to metal contact. It seems to me this design will wear fast and not be very smooth.
Brady
PostPosted: Tue Nov 11, 2008 1:00 pm    Post subject: Re: CH701 nose wheel bearing Reply with quote
There should be no metal to metal, the strut rides in a nylon block bearing.
How old are your plans?
Brady McCormick
Poulsbo, WA
JohnDRead(at)aol.com
PostPosted: Tue Nov 11, 2008 1:05 pm    Post subject: CH701 nose wheel bearing Reply with quote
I think it is a ball bearing unit.
John Read
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
In a message dated 11/11/2008 1:47:22 P.M. Mountain Standard Time, gusjohnson008(at)gmail.com writes:
--> Zenith701801-List message posted by: "gus" <gusjohnson008(at)gmail.com>
http://forums.matronics.com/viewtopic.php?p=213561#213561
AOL Search: Your one stop for directions, recipes and all other H1200798498/aol?redir=http://searchblog.aol.com/2008/11/04/happy-holidays-from-aol-search/?ncid=emlcntussear00000001 ">Search Now.
Brady
PostPosted: Tue Nov 11, 2008 2:32 pm    Post subject: Re: CH701 nose wheel bearing Reply with quote
The bearing that the strut rides in is Nylon.
I understood that to be the bearing he was talking about.
The Nose Wheel bearing is a ball bearing.
I think he said "nose wheel strut" bearing.
Brady McCormick
Poulsbo, WA
gus
PostPosted: Tue Nov 11, 2008 5:25 pm    Post subject: Re: CH701 nose wheel bearing Reply with quote
yes a nylon block , thats what I have seen. My drawings are dated 09/01. Do the block specs include the "gear extended self centering ramps? Are drawings available for the nylon version? Thanks for the help.
craig(at)craigandjean.com
PostPosted: Tue Nov 11, 2008 5:43 pm    Post subject: CH701 nose wheel bearing Reply with quote
The attached photo is actually from an HD (Larry McFarland's?) but the
design on my 701 looks the same and I'll be adding the nylon. Basically add
nylon plates with V notches inside and parallel to the aluminum angle.
-- Craig
 Filesize:  88.86 KB
 Viewed:  784 Time(s)
PostPosted: Tue Nov 11, 2008 5:50 pm    Post subject: CH701 nose wheel bearing Reply with quote
Even the latest plans (7-L-1 dated 04/2006) show the V notch as bare
aluminum (7F8-6 dated 06/2005). I sent a picture in another message showing
how to add nylon V notches.
-- Craig
gus
PostPosted: Wed Nov 12, 2008 5:43 pm    Post subject: Re: CH701 nose wheel bearing Reply with quote
The pictures look good. I have some 1/4" Nylatron sheet stock, that should fit well. Thanks for the pictures.
gus
PostPosted: Mon Nov 17, 2008 6:40 am    Post subject: Re: CH701 nose wheel bearing Reply with quote
In order to get full bearing contact I'm considering lathe turning two bushings , these would require opening the 2" up to 2 1/4" on 7.F.8.4 ,7.F.8.5 and 7.F.7.4 . I would leave a flange on these bushings to allow bolting or riveting in place . They would also need a saw cut to allow them to fit over the nose gear strut assy. 7.L.1.1. My concern with the method in the photo is after the nylon wears a little , we will be back to metal on metal. What are your thoughts on this method ? Thanks Gus
