jonboede(at)hotmail.com Guest
Posted: Sun Nov 09, 2008 9:01 pm Post subject: sputtering on stop |
I have a 285 hp CJ that seems (as much as anyone can tell that sort of thing) to be running a little rough.
Seems to cough a bit and turns backwards when it stops although that seems normal for a radial C but it seems to be doing it more than it was in the past.
Adjusted all exhaust valves and compression check turns up 70+ on all cylinders cold C except #4 that gets about 50 (cold) and is scheduled for a good valve re-lapping.
Wobble pump doesn't seem to do much in this Chang... could that have anything to do with things?
Thanks C
jon
Posted: Mon Nov 10, 2008 9:44 am Post subject: sputtering on stop |
Jon,
What is your shut down proceedure?
Doug
On Sun, Nov 9, 2008 at 8:56 PM, Jon Boede <jonboede(at)hotmail.com (jonboede(at)hotmail.com)> wrote:
| Quote: | I have a 285 hp CJ that seems (as much as anyone can tell that sort of thing) to be running a little rough.
Seems to cough a bit and turns backwards when it stops although that seems normal for a radial, but it seems to be doing it more than it was in the past.
Adjusted all exhaust valves and compression check turns up 70+ on all cylinders cold, except #4 that gets about 50 (cold) and is scheduled for a good valve re-lapping.
jon
Always Yakin,
Doug Sapp
Phone 509-826-4610
Fax 509-826-3644
