Ken
Posted: Sun Nov 09, 2008 6:06 pm Post subject: Diodes |
I have an electric primer valve. Do I need to put a diode across it to protect the system from the induced voltage spikes? Also I am using a Sky-Tec starter on a Lycoming O-235. As you know they can be used in either mode. You can use the electric solenoid on the starter or you can leave it jumpered and use a solenoid on the firewall. I'm going the firewall solenoid route so that the starter cable is only carrying voltage while cranking. Do I need to put a diode on the starter or just on the firewall solenoid or both?
Thanks in advance
SABorns(at)aol.com Guest
Posted: Sun Nov 09, 2008 7:42 pm Post subject: Diodes |
Check out Aircraft Spruce item 11-05727. This is the Transorb used by MGL electronics to protect the avionics bus from transient voltages. You might also put diodes across the coils of your master and starter solenoid (cathode (banded end) to +, anode to ground). For more information on spike protection google
"Transorb".
Steven Bornstein
475 E. North Broadway
Columbus, Ohio 43214
614 263-5819
In a message dated 11/9/2008 9:07:24 P.M. Eastern Standard Time, hror1(at)pld.com writes:
| Quote: | --> Zenith-List message posted by: "Ken" <hror1(at)pld.com>
Thanks in advance
http://forums.matronics.com/viewtopic.php?p=213187#213187
AOL Search: Your one stop for directions, recipes and all other H1200798498/aol?redir=http://searchblog.aol.com/2008/11/04/happy-holidays-from-aol-search/?ncid=emlcntussear00000001 ">Search Now.
Posted: Sun Nov 09, 2008 8:06 pm Post subject: Diodes |
Just did some checking on part numbers. MGL and Aircraft Spruce get $6.00 for a transorb. You can obtain the same part from Mouser Electronics for less than a dollar. Search P/N 1.5KE33 or IN6284A.
Steven Bornstein
614 263-5819
Thanks in advance
