Help! Need a mechanic in East Texas
N642K
PostPosted: Fri Nov 07, 2008 9:58 pm    Post subject: Help! Need a mechanic in East Texas Reply with quote
Do you know a good mechanic near Tyler TX? I'm cross country and she's hemmoraging oil. I need an honest radial engine mechanic. Sad
drc(at)wscare.com
PostPosted: Sat Nov 08, 2008 8:53 am    Post subject: Help! Need a mechanic in East Texas Reply with quote
The closest I know is Steve Culp in Shreveport, LA ( about 90 miles
east KDTN)
Culp Specialties. He has a Yak and had a Wilga and is very familiar
with the engine and has a fair supply of parts.
Herb
http://forums.matronics.com/viewtopic.php?p 13000#213000
jimscjs(at)mbay.net
PostPosted: Sat Nov 08, 2008 9:02 am    Post subject: Help! Need a mechanic in East Texas Reply with quote
N642K Bill Talutis Lives in Tyler and has a CJ-6 and also is a A&P, a real
nice Guy his Number is 831 229-0019
Jim Selby
dougsappllc(at)gmail.com
PostPosted: Sat Nov 08, 2008 11:36 am    Post subject: Help! Need a mechanic in East Texas Reply with quote
Mike,Dont know how close he is but try Bob Wagstaff 281-798-7728 cell
Good luck,
Doug
On Fri, Nov 7, 2008 at 9:58 PM, N642K <mdecanio(at)mac.com (mdecanio(at)mac.com)> wrote:
--> Yak-List message posted by: "N642K" <mdecanio(at)mac.com (mdecanio(at)mac.com)>
[url=http://forums.matronics.com/viewtopic.php?p 13000#213000]http://forums.matronics.com/viewtopic.php?p 13000#213000[/url]
Always Yakin,
Doug Sapp
Phone 509-826-4610
Fax 509-826-3644
flushjohnson(at)charter.n
PostPosted: Sat Nov 08, 2008 4:59 pm    Post subject: Help! Need a mechanic in East Texas Reply with quote
We have a couple of good Machs in the DFW area. Whwre are you leaking.?
N642K
PostPosted: Sat Nov 08, 2008 5:53 pm    Post subject: Re: Help! Need a mechanic in East Texas Reply with quote
Hi Forrest! It's Mike DeCanio. It appeared to be leaking everywhere! Lost nearly 3 quarts in a 30 minute flight. Jim Selby turned me onto Bill Talutis here at Tyler. What a gentleman. 3 minute diagnosis = loose cylinder head. He doesn't have any time to get to it so I'm gonna have to get somebody to travel here or wait a while to get the plane back. If you can recommend somebody, I'll listen. Jerry Pockrus is my regular mechanic, he's at Clark Field. I'm gonna see if he's interested in being a journeyman.
That extra vibration meant the death of my original exhaust so I'm also in the market for a stainless system. Laughing
Thanks to everybody for your inputs. Really proved the worth of this forum when somebody could recommend a fellow CJ pilot and A&P at the very field I'm having diffulculties.
alikatz(at)mbay.net
PostPosted: Sat Nov 08, 2008 6:10 pm    Post subject: Help! Need a mechanic in East Texas Reply with quote
Mike,
Great to hear you and Bill hooked up today, he's a great guy.. If Doug
doesn't have the SS Exhaust system in Stock, you might want to contact
Richard at Aircraft Exhaust Inc. his number is below... Good luck on the
Fix.
Best Regards
Jim Selby Jr
1-800-770-7287
ronwasson
PostPosted: Sat Nov 08, 2008 9:05 pm    Post subject: Help! Need a mechanic in East Texas Reply with quote
I have had loose cylinders twice on my CJ. It is a low tech time
consuming fix. You need a metric cylinder base wrench from Doug and a
metric crowfoot set. Remove the cowl and find the loose cylinder.
Anything in the way comes off mostly the spring loaded baffle plates
between the cylinder. Bend the nut tabs down and tighten to 60
pounds or at least good and tight to get you down the road to have it
re torqued. You can do this. Doug has the base wrenches or even a
metric crowfoot should work from Sears. This is as simple as tighten 6
nuts on the base of the leaking cylinder and putting the baffling back
on. Clean the motor with degreaser or even can engine no foam
degreaser from a parts store and check for leaks. This a very common
issue on the CJ. No one does it but I was told by an old round motor
crop duster that they retorqued every annual and always found a couple
nuts loose on a motor. Bob wagstaff is in Houston or 200 plus miles
ron
wlannon(at)persona.ca
PostPosted: Sat Nov 08, 2008 9:37 pm    Post subject: Help! Need a mechanic in East Texas Reply with quote
The cylinder hold down nuts should be torqued to 300/320 in lb (25/26 ft
lb).
Walt
ronwasson
PostPosted: Sat Nov 08, 2008 9:53 pm    Post subject: Help! Need a mechanic in East Texas Reply with quote
Your right on the torque Walt . I just looked and my memory is bad.
(25/26 ft lb).
Walt
dsavarese0812(at)bellsout
PostPosted: Sun Nov 09, 2008 5:31 am    Post subject: Help! Need a mechanic in East Texas Reply with quote
Thanks Walt. You beat me to it. Also applies to the M14 cylinders as well. For those that need it, attached is a torque spec chart.
Dennis
TORQUE_SPECS.XLS
 Filename:  TORQUE_SPECS.XLS
 Filesize:  16.5 KB
 Downloaded:  515 Time(s)
kregg(at)balancemyprop.co
PostPosted: Sun Nov 09, 2008 2:26 pm    Post subject: Help! Need a mechanic in East Texas Reply with quote
I have a new stainless slip fit exhaust if you need one.
Kregg Victory
jonboede(at)hotmail.com
PostPosted: Sun Nov 09, 2008 8:53 pm    Post subject: Help! Need a mechanic in East Texas Reply with quote
I second the "loose cylinder head" diagnosis... I have had two and both times it lost about three quarts in a 45 minute flight.
[quote] From: kregg(at)balancemyprop.com
To: yak-list(at)matronics.com
Subject: RE: Re: Help! Need a mechanic in East Texas
Date: Sun C 9 Nov 2008 14:25:28 -0800
--> Yak-List message posted by: "Kregg Victory" <kregg(at)balancemyprop.com>
Kregg Victory
