Firestar II Windshield
Tom463(at)aol.com
PostPosted: Sun Mar 19, 2006 5:23 pm    Post subject: Firestar II Windshield Reply with quote
I recently purchased a Firestar II with the full enclosure and I do NOT like
the center tube in front of my face. I need the full enclosure due to
health reasons. Any suggestions on SAFE methods to remove the obstruction and
still maintain the stability of the windshield?
John Jung
PostPosted: Sun Mar 19, 2006 6:18 pm    Post subject: Re: Firestar II Windshield Reply with quote
Tom.
Mesure the thickness of your windscreen. If it is .090", just remove the bar. If it is less than .090, make a new on out of .090 Laxan and then remove the bar. I didn't like the bar either. Mine has been gone for 7 years.
John Jung
Firestar II N6163J
Surprise, AZ
Larry Cottrell
PostPosted: Sun Mar 19, 2006 10:08 pm    Post subject: Firestar II Windshield Reply with quote
If that is the original factory supplied windshield, then you can take out
the center bar. It is tough enough to take any speed that you are likely to
go with no distortion.
Larry, Oregon
Tom463(at)aol.com
PostPosted: Mon Mar 20, 2006 3:39 am    Post subject: Firestar II Windshield Reply with quote
I have a friend who is telling me the same thing, but he has no Kolb
experience to base his suggestion on.
I have a 503DCDI and sometimes get close to 80MPH for short periods. Do you
fly that fast?
Your input makes me feel better about removing the bar, but I'd appreciate
your speed info.
Tom Yowell
Florida Flying Gators
Clermont, Florida
Larry Cottrell
PostPosted: Mon Mar 20, 2006 9:05 am    Post subject: Re: Firestar II Windshield Reply with quote
I assume that you are talking about the factory enclosure. If so it will not buckle. To check it close the windshield, put your hand in the middle at the furtherest point from any support and push. If it feels squishey, don't do it. While I took out the center post, I did retain the screw that held it at the top of the pod. Remember the wind is not hitting it at a 90 degree angle. I have seen 90 on mine, but not on purpose. Or you could do it like this, it is a lot more trouble.
Larry, Oregon
 Filesize:  437.32 KB
 Viewed:  639 Time(s)
Larry Cottrell
PostPosted: Mon Mar 20, 2006 9:18 am    Post subject: Re: Firestar II Windshield Reply with quote
Well I see I still don't have the hang of the attachment part of this BB. I don't seem to be able to preview my post, and have to do it by trail and error. Seems mostly like error. Here is the other picture. I decided that I wanted doors, so I built this one. I of course had to order chromoly,hinges, and a sheet of lexan. Weld the new doors and fit the lexan. I like it, but I wasn't able to get the thickness of lexan that I would have prefered. (0 is too think and the one that I have is a bit too thin, but is still usable.
Larry,Oregon
 Filesize:  424.53 KB
 Viewed:  597 Time(s)
eagle1(at)commspeed.net
PostPosted: Mon Mar 20, 2006 9:57 am    Post subject: Firestar II Windshield Reply with quote
I didn't like it either, so used a tube on each side of the insturment
panel, back up to the steel framework behind my head. I then used the right
new tube for the hinge for the door. I no longer have the plane or I could
send you a picture.
Az Bald Eagle
John Jung
PostPosted: Mon Mar 20, 2006 11:57 am    Post subject: Re: Firestar II Windshield Reply with quote
Tom,
The information that I gave you about using .090" Lexan without the bar was from the old Kolb company. I have flown 90 mph many times without the bar, but I know of no one flying without the bar and .060 Lexan.
John Jung
Firestar II N6163J
Surprise, AZ
N111KX (Kip)
PostPosted: Mon Mar 20, 2006 4:04 pm    Post subject: Re: Firestar II Windshield Reply with quote
I used 1/8 inch thick Lexan to make a custom windshield. It's very rigid but takes 3 people to bend it while installing on the plane.
Here is a view...
http://www.springeraviation.net/
Kip
Kip
Firestar II, N111KX
Waiex, N111YX
Quickie 1, N111QX
Atlanta
scrounge69(at)alltel.net
PostPosted: Mon Mar 20, 2006 5:52 pm    Post subject: Firestar II Windshield Reply with quote
Kip,Thanks for the great pictures , they really took me back, We all know
Homer designed great airplanes but what a wonderful sightseeing aircraft and
its a photographers dream, slow, steady and and if your lexan is clear and
you have a camera a great place to take a 1000 pics so you can share the
love of flight we all have. Thanks again, Chris Davis
