rd2(at)evenlink.com Guest
Posted: Sun Mar 19, 2006 12:40 pm Post subject: carburated -> fuel injected |
Hello listers,
I was wondering, can a carburated Lycoming O-360-A4M 180 HP Penn Yan
conversion be converted to fuel injected?
I understand most cylinders have bosses for fuel injectors (plugged on the
carbureted models). Not sure if our engine has such bosses and how to check.
Thanks for any pointers.
Rumen
| | - The Matronics Engines-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Engines-List |
klwerner(at)comcast.net Guest
Posted: Sun Mar 19, 2006 1:11 pm Post subject: carburated -> fuel injected |
Rumen,
Yes, you should be able to convert the -A4M to Fuel Injection. Look at a cylinder around the intake port. You should see two plugs there. The upper plug is where you would put in the Fuel Injector for that cylinder.
Perhaps one or more of your cylinders may have a primer nozzle installed in the lower port of any given cylinder?
Good Luck,
Konrad
Posted: Sun Mar 19, 2006 2:24 pm Post subject: carburated -> fuel injected |
Thanks, Konrad.
I am told there are no such STC's on file (so we could look up what
components are needed), so how do we assemble a list of needed components
(besides the injectors)?
_____________________Original message __________________________
(received from Konrad L. Werner; Date: 02:10 PM 3/19/2006
-0700)
Rumen,
Good Luck,
Konrad
Posted: Sun Mar 19, 2006 9:48 pm Post subject: carburated -> fuel injected |
STC??? It is for an experimental aircraft, or is it not? If not then I do not have an answer for you. But if it is for an experimental, then you may contact Airflow Performance for their fine system (...or any of the major engine builders for their opinion on what parts are necessary to make it happen).
Good Luck,
Konrad
Posted: Mon Mar 20, 2006 3:41 am Post subject: carburated -> fuel injected |
No, Konrad, unfortunately it is being considered for a production aircraft.
That means field approval (if it can be done). But first we need to find
out how big of a project it might become, then the approval will be
addressed. At the end it might not materialize at all.
Best
Rumen
(received from Konrad L. Werner; Date: 10:43 PM 3/19/2006
-0700)
happen).
Good Luck,
Konrad
flyv35b(at)ashcreekwirele Guest
Posted: Mon Mar 20, 2006 7:04 am Post subject: carburated -> fuel injected |
Contact your local FSDO and talk to them about your intentions. I think
they will say you have to go through the ACO engineering and apply for an
STC. It is highly unlikely they would do a field approval from a FSDO.
Cliff A&P/IA
Posted: Mon Mar 20, 2006 7:15 am Post subject: carburated -> fuel injected |
Thanks for the tip, Cliff
Rumen
(received from flyv35b; Date: 07:01 AM 3/20/2006 -0800)
Cliff A&P/IA
GrummanDude
Posted: Mon Mar 20, 2006 11:40 am Post subject: carburated -> fuel injected |
In a message dated 3/20/06 9:28:04 AM, rd2(at)evenlink.com writes:
Contact your local FSDO and talk to them about your intentions.=A0 I think
STC.=A0 It is highly unlikely they would do a field approval from a FSDO.
Actually, LyCon has taken one model and converted it to another during
overhaul. You still have the original tag, but, the paperwork shows what's been
done.
_________________ Gary
AuCountry Aviation
Home of Team Grumman |
