Interesting reading about cable tensions
Martin Pohl
PostPosted: Tue Nov 04, 2008 7:12 am    Post subject: Interesting reading about cable tensions Reply with quote
Interesting reading about a cable tension test on 14 XLs in Belgium:
http://www.zenairulm.com/News/index_files/Page387.htm
Cheers Martin
Martin Pohl
Zodiac XL QBK
8645 Jona, Switzerland
http://www.pohltec.ch/ZodiacXL/Main.html
tigerrick(at)mindspring.c
PostPosted: Tue Nov 04, 2008 9:52 am    Post subject: Interesting reading about cable tensions Reply with quote
Wow! I just downloaded and printed out the 9 page Zenair Photoguide to properly checking and retensioning 601 airframe cables, and I must say I'm really impressed by it's scope and content.
Should be considered required reading for y'all. IMHO.
Rick Lindstrom
N42KP
craig(at)craigandjean.com
PostPosted: Tue Nov 04, 2008 10:08 am    Post subject: Interesting reading about cable tensions Reply with quote
If you don't want to build Larry McFarland's simple and dirt cheap tension gauge Spruce sells the Burroughs gauge shown in the Zenith pictorial for well under $200.
http://www.aircraftspruce.com/catalog/topages/cablegauge.php
Either way the pictorial shows the easy way to calibrate these.
-- Craig
Gig Giacona
PostPosted: Tue Nov 04, 2008 1:06 pm    Post subject: Re: Interesting reading about cable tensions Reply with quote
The same info is posted in the builders area on the US Zenith site now. Just in case any of you feel the need to get it from the same company where you bought your Kit/Plans.
W.R. "Gig" Giacona
601XL Under Construction
