Ethanol / g`soline mixture
esteuber(at)rochester.rr.
PostPosted: Sun Mar 19, 2006 11:30 am    Post subject: Ethanol / gasoline mixture Reply with quote
All,
I don't believe it should cause a big problem for the people with engines that can adapt the oil injection to their particular engines like all the Rotex models . I was told the oil does not mix well with the alcohol and a lubrication problem can result.....In my case I am running 2 Cuyuna's (Ul202) on my Kolb and CGS Hawk that I don't believe can be adapted to oil injection. I do know 2SI was in the process of supplying 28 HP 2 cycle engines of the same configuration to the military that run on jet fuel...I think they are using an injector system on it ...anybody know ? Of course they no longer support the ultralight community because of past litigation so don't plan on pulling up to the jet fuel pumps any time soon ...
Unless I buy one of those pulse jet engines on E-bay ...then I could install a bottle jack between the front wing attach points and sweep the wings in flight on the Ultrastar.....NAAAAWW !........ then I'd have to put 7 ribs in the wings !
Mach .1 ED in Western NY
