jim(at)CombsFive.Com Guest
Posted: Sun Nov 02, 2008 6:34 pm Post subject: Advanced SV - was Flying with AFS EFIS - mid west.... |
Rob,Is the plan:(1) Swap out entire 3400 / 3500 unit (Receive a different serial numbered system) (2) Remove unit from airplane and send to you for upgrade (we keep same serial number unit but have some down time)(3) You send new CPU board to us and we do the swap (Not likely)?(4) something I have not listed?As a 3500 owner, I am very curious. I won't ask about pricing. That can wait till you are ready. So far, I am a very pleased customer.Jim C (40192, N312F)Finally got the weight an balance stuff straightened out (added 25 lbs at the horizontal Stab spar in the tail cone and reweighed with two sets of scales). Verified ALL the numbers and finally got the CG where I wanted it (and where it should be). Will adjust rear ballast weight as the airplane gets painted and interior is installed (sometime next year). > > In a message dated 10/31/2008 5:11:22 P.M. Pacific Standard Time,> cj(at)popstudios.com writes:> > I've heard the little hints about your synthetic vision and was wondering> if> you'd be willing to share any details? Specifically whether it will be> available for the 3400 and 3500 when it comes? C'mon, I know you're> just> itching to talk about it!!! Give us a little taste!> > > > We will have an upgrade for the 3400 and 3500, it will be a new> processor> board that will run the Advanced SV. We are on track to have the upgrades> and Advanced SV before Sun-n-Fun. The few people that have seen it have> been> very impressed with how good it looks; we even already have the runways.> I have tried all of the latest EFIS systems, I even had the opportunity> to> fly a new Cirrus G3 Turbo Perspective last week. I was very impressed> with> the EFIS’s in the Perspective; the new Cirrus Jet even took off right> after> us. We know where we need to be with our level of features and our > customers> will not be disappointed.> > Rob Hickman> Advanced Flight Systems> > > **************Plan your next getaway with AOL Travel. Check out Today's> Hot> 5 Travel Deals!> ttp://travel.aol.com/discount-travel?ncid=emlcntustrav00000001)> [quote][b]
RobHickman(at)aol.com Guest
Posted: Mon Nov 03, 2008 7:52 am Post subject: Advanced SV - was Flying with AFS EFIS - mid west.... |
In a message dated 11/2/2008 6:36:18 P.M. Pacific Standard Time, jim(at)combsfive.com writes:
| Quote: | Rob,
Is the plan:
You will need to send us the unit and we will replace the main cpu board in the system.
Rob Hickman
N402RH RV-10
Plan your next5x1212416248x1200771803/aol?redir=http://travel.aol.com/discount-travel?ncid=emlcntustrav00000001">Check out Today's Hot 5 Travel Deals!
