colin(at)ptclhk.com Guest
Posted: Sat Jan 07, 2006 11:11 pm Post subject: NSI CAP Control Unit Circuits |
Hi Folks,
I am presently looking over the NSI prop control unit out of Graeme Tofts'
ditched Kitfox. After a thorough cleanup it looks pretty good, especially
considering that if forgot it was out of an aircraft and tried to be a
submarine controller for a few hours. There are no fried tracks and
components, so I am quite hopefull that it can be resurrected.
Before I launch into the unknown, I thought I would ask if anyone on the
list has a copy of the circuit schematics for this unit, or at least, a
connection diagram. This will make my job a lot easier, otherwise, I'll
just have to do it the hard way and trace everything out first.
Any help that you can give will be greatly apreciated.
Colin Durey
Sydney
+61-418-677073 (M)
+61-2-945466162 (F)
morid(at)northland.lib.mi Guest
Posted: Sun Jan 08, 2006 5:17 am Post subject: NSI CAP Control Unit Circuits |
Colin, my control unit filled with water when my airplane sat out in a heavy
thunderstorm. This was before I came up with a good seal and drain trough
for the windshield. The only reason I found that it had water in it was
because the pitch control became erratic. After removal, a good clean with
soap and water, and thoroughly dried, it's worked fine ever since.
I doubt there'll be anything wrong with it once it's cleaned up nicely.
As for schematics, none that I know of outside of the factory. However, if
you find that it isn't working properly you might try Mykal Templeman from
Stratus Subaru. I think he might have access to CAP parts.
Deke
Posted: Sun Jan 08, 2006 1:22 pm Post subject: NSI CAP Control Unit Circuits |
Thanks Deke,
I've pretty sure it will be OK, however, this unit was submerged in salt
water for a while which is pretty agressive and, it went in with power
still applied. The only real concern I have is the micro-controller. If it
is dead, while I can certainly get another (its a standard component), I
would need to then get my hands on the firmware.
Thanks for the contact name. If I need to, I'll give him a call.
Colin Durey
Sydney
+61-418-677073 (M)
+61-2-945466162 (F)
heavy
with
if
Deke
szakreski(at)shaw.ca Guest
Posted: Mon Jan 09, 2006 9:38 am Post subject: NSI CAP Control Unit Circuits |
Colin
I have the external wiring diagram. Is that what you want?
SteveZ
Calgary
