dmasys(at)cox.net Guest
Posted: Sat Mar 18, 2006 11:51 am Post subject: Sharpie marks on wingtip lens |
I got a few straw blue sharpie marks on my wingtip lens. Tested various solvents on a scrap piece to see if they would take the marks off without dulling the surface of the plastic, and confirmed that MEK, Laquer thinner, and Acetone all damage the plastic. WD-40 is ok, but doesn't take the marks off . Anybody know of a safe solvent?
Thanks in advance,
-Dan Masys
#400448 Finishing wings
seipel(at)seznam.cz Guest
Posted: Sat Mar 18, 2006 2:14 pm Post subject: Sharpie marks on wingtip lens |
Try alcohol. I use it to take sharpie markings off of laminated maps.
It may work without damaging your lens.
PJ
RV-10 #40032
Dan Masys wrote:
Thanks in advance,
-Dan Masys
jesse(at)itecusa.org Guest
Posted: Sat Mar 18, 2006 3:18 pm Post subject: Sharpie marks on wingtip lens |
Sounds like time to get artistic and turn those marks into a design or
drawing and make it look like you meant to do it. Actually, have you tried
409 or something like that. We use thinner down here in Ecuador for
everything. Maybe trying a different type of thinner would help.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
I'm in Ecuador right now and should be back in the country by the end of
May. You may call me at 352-505-1899 and leave a message that I can check
from down here. Any I-TEC questions can be directed to the I-TEC office at
352-465-4545.
jeremy.p.harris(at)boeing Guest
Posted: Sat Mar 18, 2006 4:30 pm Post subject: Sharpie marks on wingtip lens |
How about buffing it with a plastic polishing wheel?
Jeremy P. Harris
Integrated Missile Defense
BMDS Architectures Lab
The Boeing Company
Washington, DC
Desk: (703) 414-6057 Dept: AV-2L-B27T
Cell: (703) 627-6500
Fax: (703) 414-6372
MC: 793C-G007
Office: 825B
gommone7(at)bellsouth.net Guest
Posted: Sat Mar 18, 2006 4:43 pm Post subject: Sharpie marks on wingtip lens |
| Quote: | You need 3M general purpose adhesive cleaner,Home depot,not damaged pastic,is a quarter can with a red sticker.Its the only cleaner for markers and any can of glue remain in surfaces from stickers,and chewing gums in the carpets.
Hugo
| Quote: | From: Dan Masys <dmasys(at)cox.net>
Date: 2006/03/18 Sat PM 02:49:48 EST
Subject: Sharpie marks on wingtip lens
Thanks in advance,
-Dan Masys
johnwcox(at)pacificnw.com Guest
Posted: Sat Mar 18, 2006 5:45 pm Post subject: Sharpie marks on wingtip lens |
Page 2 and 84 of the attached document. Kerosene or Isopropyl Alcohol.
Nothing else. Crazing can begin more than a year later when the solvent
has chemically stripped key components from the acrylic. Poorly
educated Line Boys can inadvertently wipe with Windex and set the
consequence in motion. Best answer, clear, plain de-ionized water and
lots of it.
John - $00.02
LP_Aero_cat.pdf |
337.02 KB |
1798 Time(s) |
Tim(at)MyRV10.com Guest
Posted: Sat Mar 18, 2006 6:00 pm Post subject: Sharpie marks on wingtip lens |
Not that I'd recommend doing this to fix the blue sharpie problem,
but I found that I had left my lenses in the garage while painting
other parts. They had a dusting of overspray on them. I had in
the past on my old plane used the "Scratch off" kit to remove
windshield scratches, and it worked great, so I used it again
and polished my lenses and got rid of the overspray. I also have
a tiny bit of overspray on a couple windows that leaked through
tape that must not have been tight enough, so before SNF I'll
be using it on my new windows.
Just thought I'd pass that on so you know it works and if anyone
gets any scratches on their windows it's a great product.
Jeremy P. Harris
The Boeing Company
Washington, DC
Fax: (703) 414-6372
MC: 793C-G007
Office: 825B
n223rv(at)wolflakeairport Guest
Posted: Sat Mar 18, 2006 7:45 pm Post subject: Sharpie marks on wingtip lens |
Try lighter fluid, works on canopies pretty well. Also, you can use
Novus.
johncleary(at)mangertonns Guest
Posted: Sun Mar 19, 2006 1:00 am Post subject: Sharpie marks on wingtip lens |
Try methylated spirits,
John
