Sub Panel Labeling
hammer408(at)comcast.net
PostPosted: Thu Oct 30, 2008 1:43 pm    Post subject: Sub Panel Labeling Reply with quote
Gentlemen:
I've seen numerous e-mails, etc regarding panel labeling, but I really
didn't see comments regarding the "COLOR" of the lettering. I've researched
thru various FAA sites, etc., and I couldn't find articles as to what the
"Legal" color for lettering should be (black, white).
I have a meduim Gray Panel (see attachment) and I'm leaning towards BLACK
Lettering...it stands out better.
I woud appreciate any feedback or suggestions.
Henry
Pittsburgh, Pa.
RV-9A - wiring started
 Filesize:  19.98 KB
 Viewed:  270 Time(s)
raymondj(at)frontiernet.n
PostPosted: Thu Oct 30, 2008 3:18 pm    Post subject: Sub Panel Labeling Reply with quote
Greetings Henry,
I will be using flat gray for my panel. My experience has been that
white stands out much better in a low light situation. I think white will
give better readability in low ambient light and allow me to have the
instruments lights dimmer which will allow better night adaptation of my
eyes.
Raymond Julian
Kettle River, MN
"Hope for the best,
but prepare for the worst."
stein(at)steinair.com
PostPosted: Thu Oct 30, 2008 3:49 pm    Post subject: Sub Panel Labeling Reply with quote
Hi Henry,
I don't think there is an actual FAR for coloring of labels, but
conventional practice in the business (we do this for a living, so we see it
every day) is to use a contrasting color. If the panel is light-use dark
labels, if the panel is dark - use light labels. We see the most popular
panel colors as Black, Greys, Tan's/Beige and off white colors. If we were
building your panel with the color you've attached, I'd really push you
towards black lettering for a number of reasons.
My 2 cents as usual!
Stein
Minneapolis, MN
[quote]--
Gilles.Thesee(at)ac-greno
PostPosted: Thu Oct 30, 2008 4:05 pm    Post subject: Sub Panel Labeling Reply with quote
SteinAir, Inc. a écrit :
I'd really push you
I personally would tend to use white against medium gray for reasons of
low light visibility.
Not everyone has the same perception under such conditions, so I'd
conduct some tests in low light : what about visibility at dusk with no
panel lights ? What about readability under fluorescent light or
whatever is installed/employed for night lighting ?
I get the impression that white stand out better than dark figures, just
like instrument numbers, but of course others may differ.
FWIW,
Best regards,
GillesThesee
http://contrails.free.fr
wgill10(at)comcast.net
PostPosted: Thu Oct 30, 2008 6:04 pm    Post subject: Sub Panel Labeling Reply with quote
Henry,
Attached are a few examples from my project.
Bill
RV-7 N151WP
 Filesize:  211.35 KB
 Viewed:  283 Time(s)
 Filesize:  233.23 KB
 Viewed:  289 Time(s)
 Filesize:  180.61 KB
 Viewed:  259 Time(s)
 Filesize:  215.52 KB
 Viewed:  322 Time(s)
gcomfo(at)tc3net.com
PostPosted: Fri Oct 31, 2008 4:11 am    Post subject: Sub Panel Labeling Reply with quote
PostPosted: Fri Oct 31, 2008 6:36 am    Post subject: Sub Panel Labeling Reply with quote
Hi Gilles,
I tend to respectfully disagree here. White lettering on Gray panels is
notoriously poor under almost all conditions. Unless the gray is fairly
dark (almost a charcoal color), white letters get washed out and lost, and
it happens in both high brightness and low brightness situations. Night
time will highlight the differences even more. While you may lean towards
thinking white is better at night, if it's over a light base, the letters
get lost even quicker and worse than in bright light. It may be a bit
counter intuititve to first thought, but white letters on light panels just
doesn't work well at all for the most part. The main goal is to get the
most contrast you cat between the base panel color and the lettering,
regardless of what those colors may be. For example the best you can get on
black is to use silver lettering (it's even better than white). On a dark
maroon panel it happens to be gold foil lettering. Panels that are the most
difficult are brown and some dark colors like green and red. Those are hard
to get any lettering that pops really well. I think we've experimented and
painted almost every color in the rainbow over the hundreds of panels we've
painted/labeled. I've seen the best and worst so I'm just passing along
what we've been exposed to.
My 2 cents as usual.
Stein
[quote]--
jimw_btg(at)earthlink.net
PostPosted: Fri Oct 31, 2008 7:58 am    Post subject: Sub Panel Labeling Reply with quote
Henry good looking work what did you use to make these great job!
Jim Wickert
Vision #159
Flagstone(at)cox.net
PostPosted: Sat Nov 01, 2008 12:55 pm    Post subject: Sub Panel Labeling Reply with quote
Bill:
Would you mind posting details of how you made your labels.
PostPosted: Sun Nov 09, 2008 1:03 pm    Post subject: Sub Panel Labeling Reply with quote
Bill
I don't see your attachments?
henry
