Prop strike - BEWARE!
sidsel.svein(at)oslo.onli
PostPosted: Tue Oct 28, 2008 1:16 am    Post subject: Prop strike - BEWARE! Reply with quote
Very sorry to hear about your prop strike, Kevin.
Unfortunately, the following comment on the forum is not correct, even if you have the slipper clutch:
At least with the Rotax if there is no runout problem on the prop flange you
can just bolt up a new set of blades and go again...not sure what airmaster
advises though.
Attached please find a Rotax Service Letter addressing prop strikes, and a relevant page in the most recent version of the Line Maintenance Manual re. inspections, all of which shall be carried out by authorized service personnel.
In addition to this, the Scandinavian repair center for Rotax advises that the roller bearing for the propeller shaft, mounted in the engine crank case, shall be replaced.
This information may come as a surprise to some, as it did to me when I first heard about it an authorized Rotax maintenance course. I held the fairly common misconception that if you have the slipper clutch, just replace the prop. NOT SO! The advantage, though, is that with slipper clutch the probability of damage to the gear box or the crankshaft is significantly reduced, but not eliminated. Thorough inspection according to the Rotax SL/Maintenance manual is mandatory, however. A Katana with 912S with slipper clutch here in Norway recently had a prop strike with engine damage as a result - in some instances, the damage occurs before the clutch slips, the repair center told me. Prop strike at idle RPM is sometimes worse than at high RPM, they added.
Svein
LN-SKJ
special_checks.pdf
 Filename:  special_checks.pdf
 Filesize:  192.67 KB
 Downloaded:  264 Time(s)
SL-912-015.pdf
 Filename:  SL-912-015.pdf
 Filesize:  49.5 KB
 Downloaded:  1313 Time(s)
