cowl hinges
dogsbark(at)comcast.net
PostPosted: Mon Oct 27, 2008 6:33 pm    Post subject: cowl hinges Reply with quote
[quote]I'm just getting started with the cowl and associated hinges. For those that used the stock hinge material....would you still use it if you did it again? How is it holding up? I seem to remember something mentioned of a heavier hinge material. Or...would you switch to Skybolts? I'm aware of the problem of the lower hinges losing ears, so I'll use an alternative approach there.Thanks in advance.Sean Blair#40225 [b]
ron.mcgann(at)baesystems.
PostPosted: Mon Oct 27, 2008 6:50 pm    Post subject: cowl hinges Reply with quote
Not flying yet, but if I did it again I would use proseal between the hinge and cowl before rivetting.
cheers,
Ron
-187 painting
[quote] From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of dogsbark(at)comcast.net
Sent: Tuesday, 28 October 2008 1:03 PM
Subject: cowl hinges
p://www.matronics.com/Navigator?RV10-List
ics.com
.matronics.com/contribution
"Warning:
The information contained in this email and any attached files is
confidential to BAE Systems Australia. If you are not the intended
recipient, any use, disclosure or copying of this email or any
attachments is expressly prohibited. If you have received this email
in error, please notify us immediately. VIRUS: Every care has been
taken to ensure this email and its attachments are virus free,
however, any loss or damage incurred in using this email is not the
sender's responsibility. It is your responsibility to ensure virus
checks are completed before installing any data sent in this email to
your computer."
Tim Olson
PostPosted: Mon Oct 27, 2008 7:04 pm    Post subject: cowl hinges Reply with quote
I'd use it again. It seems to be holding up just fine, and it works
better than I thought it ever would. I was a die-hard camloc
planner in the beginning but decided to give it a try and now
I'm very happy with the results. Just don't use them on the
bottom section.
dogsbark(at)comcast.net wrote:
*I'm just getting started with the cowl and associated hinges. For
so I'll use an alternative approach there.*
*Thanks in advance.*
*Sean Blair*
*#40225 *
dlm46007(at)cox.net
PostPosted: Mon Oct 27, 2008 7:24 pm    Post subject: cowl hinges Reply with quote
If you use the hinges , be sure and cover the rivet heads with a glass tape
or see the heads work their way through the paint after some hours.
pascal(at)rv10builder.net
PostPosted: Mon Oct 27, 2008 7:37 pm    Post subject: cowl hinges Reply with quote
what's wrong with using the hinges on the bottom section? what does one use
for it's replacement?
Thx
Pascal
Sent: Monday, October 27, 2008 8:04 PM
Subject: Re: cowl hinges
bottom section.
> *Sean Blair*
> *#40225 *
partner14
PostPosted: Mon Oct 27, 2008 8:07 pm    Post subject: cowl hinges Reply with quote
Can you wait until you come up next month..... I'll show you what I did...
Don
Date: Monday, October 27, 2008, 8:37 PM
--> RV10-List message posted by: "pascal"
Thx
Pascal
--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com>
bottom section.
For
ears,
> *Sean Blair*
> *#40225 *
Don A. McDonald
40636
robin1(at)mrmoisture.com
PostPosted: Mon Oct 27, 2008 9:34 pm    Post subject: cowl hinges Reply with quote
There are a lot of choices to connect your cowl. On my -10 we went all out with the sky bolts but they are unreasonably expensive and heavy IMHO. An excellent alternative to piano hinges and sky bolts or locks is a simple stainless screw. My RV-6A cowl is held together with S/S screws and they work great, look good and can you can replace 5 of them for a quarter.
The cowl uses piano hinges along the vertical lower sides but S/S screws along the top, horizontal sides & the underside. I much prefer these to piano hinges.
 Filesize:  65.98 KB
 Viewed:  569 Time(s)
 Filesize:  112.09 KB
 Viewed:  541 Time(s)
 Filesize:  117.78 KB
 Viewed:  591 Time(s)
rv(at)thelefflers.com
PostPosted: Tue Oct 28, 2008 2:57 am    Post subject: cowl hinges Reply with quote
Has anyone tried Carbinge hinges? (http://www.carbinge.com/carbinge1.htm)
recapen(at)earthlink.net
PostPosted: Tue Oct 28, 2008 4:11 am    Post subject: cowl hinges Reply with quote
I used SkyBolts around the perimeter of the firewall and heavier hinge material for the two horizontal runs.
Lew Gallagher
PostPosted: Tue Oct 28, 2008 4:28 am    Post subject: Re: cowl hinges Reply with quote
After reading about cracked ears on the cowl hinges, we decided to go with camlocs all around the firewall, and it is sooo easy to mount/disassemble the cowl. As others have said, it's a one man operation. I didn't see the need to scallop -- the weight is negligible, it's easier, and stronger.
I was searching for ideas on anchoring the hinge pin at the intake (I KNOW I saw a whole picture display of close ups at OSH or something -- maybe Tim? ... still can't find it!) and I ran across a reference to using a smaller hinge pin than the one that comes with the hinge. Did I miss something? I've been sweating getting that dang pin in, even with the extra length and an angle on the surplus, it's a really tight fit to get it all the way in. With the bottom on first, if I put the tightest side hinge pin in first, thump it toward the other side, put the second pin in, then camloc it down -- it works. Really snug! I may just hand sand down the pin if folks are using a smaller pin.
I've glassed in a tunnel from the entrance of the pin to the first ear (coated a scrap of pin with vasoline and glassed around it) so that I don't have to poke around hunting for that first ear.
Let me know if anyone knows where to find those pics of anchoring the pins. I remember one guy in that thread said he'd fed his pin in through the cabin ... Wow!
Later, - Lew
non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed !
wcurtis(at)nerv10.com
PostPosted: Tue Oct 28, 2008 8:25 am    Post subject: cowl hinges Reply with quote
http://nerv10.com/wcurtis/HingePin/
William
AV8ORJWC
Composite hinges on composite cowls... A novel idea. Kind of like metal
hinges and metal locks on metal cowls of yester year.
John Cox
Lew Gallagher
PostPosted: Tue Oct 28, 2008 9:28 am    Post subject: Re: cowl hinges Reply with quote
Thanks, William!
Yes, that was YOUR the site! There are so many good sites, sometimes I get lost.
This should be fun. And Ralph is sending me pictures on how he routed his through the cabin.
Later, - Lew
non-pilot
Fly off completed !
PostPosted: Tue Oct 28, 2008 11:00 am    Post subject: cowl hinges Reply with quote
Here is a sweet pin cover:
Robin
 Filesize:  53.75 KB
 Viewed:  531 Time(s)
carl.froehlich(at)cox.net
PostPosted: Tue Oct 28, 2008 2:09 pm    Post subject: cowl hinges Reply with quote
I ran the hinge pins aft on my 8A. They run though 1/4" aluminum tube to
out of sight bulkhead fittings under the panel. I'll do the same on the 10.
Carl Froehlich
