K Dilks
Posted: Mon Oct 27, 2008 5:13 am Post subject: Ch650 anti oil canning on 601 |
Can any one post some pictures of the anti oil canning mods on a 650 so I can incorporate them on my 601.
I can see in the promotional stuff the fuselage ones but wonder how the wing ones go.
Do they form dummy ribs like i have seen on some European models or do they run span wise like stringers between the ribs??
Kev
_________________ Back home ................. |
pavel569
Posted: Mon Oct 27, 2008 7:35 am Post subject: Re: Ch650 anti oil canning on 601 |
List of changes for CH650 wing: L angles added between ribs on top skin. Minimizes skin deformation when aircraft is in the sun and provides a
nicer finish.
_________________ Pavel
CA
Zodiac 601XL
Stratus Subaru EA-81
Tail, flaps, ailerons, wings, fuselage, canopy done ...
"do not archive" |
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Mon Oct 27, 2008 8:04 am Post subject: Re: Ch650 anti oil canning on 601 |
Here are pictures I took, at Oshkosh, of both the outside and inside of the 650's fuselage.
I hope this helps,
296.64 KB |
875 Time(s) |
267.96 KB |
892 Time(s) |
_________________ David Gallagher
Cincinnati, OH area |
Larry Hursh
Joined: 16 Feb 2008 Posts: 125 Location: Edwardsburg, MI (near Elkhart, IN)
Posted: Mon Oct 27, 2008 12:26 pm Post subject: Re: Ch650 anti oil canning on 601 |
I just got off the phone with Travis at Zenith, Mexico, MS. He said he thought he had a picture, showing the layout on the wing for the bracing in the rib bays, between the ribs I've ordered extra "L" angles and hopefully, Travis will be able to put that picture in my shipment to me, or in the mail. If he does send me a photo, I WILL post it here on the website for those wishing to do this upgrade.
_________________ Larry Hursh (N650LM Reserved)
"One rivet at a time......one day at a time.."
CH650 (Converted from CH601XL)
1/2 done with fuselage
will be Corvair Powered |
Gig Giacona
Posted: Mon Oct 27, 2008 1:23 pm Post subject: Re: Ch650 anti oil canning on 601 |
You can't have to many L angles on hand. You will use more than the plans show and in many places not shown on the plans even if you don't add the cross braces.
| skyridersbn wrote: | | I just got off the phone with Travis at Zenith, Mexico, MS. He said he thought he had a picture, showing the layout on the wing for the bracing in the rib bays, between the ribs I've ordered extra "L" angles and hopefully, Travis will be able to put that picture in my shipment to me, or in the mail. If he does send me a photo, I WILL post it here on the website for those wishing to do this upgrade. |
601XL Under Construction
Posted: Mon Oct 27, 2008 1:43 pm Post subject: Ch650 anti oil canning on 601 |
It isn't too hard to make your own standard L's in 4 foot lengths with a
simple wooden press break. Pictures attached.
-- Craig
100.51 KB |
803 Time(s) |
96.14 KB |
788 Time(s) |
89.8 KB |
787 Time(s) |
97.7 KB |
778 Time(s) |
96.78 KB |
860 Time(s) |
pavel569
Posted: Mon Oct 27, 2008 4:28 pm Post subject: Re: Ch650 anti oil canning on 601 |
Have you guys noticed thickness of the rear fuse sides on the picture? It's .020", 601 XL has .025" maybe that's why they added those "L" profiles.
CA
Zodiac 601XL
"do not archive"
jmaynard
Joined: 27 Feb 2008 Posts: 394 Location: Fairmont, MN (FRM)
Posted: Tue Oct 28, 2008 5:02 am Post subject: Ch650 anti oil canning on 601 |
On Mon, Oct 27, 2008 at 03:40:28PM -0600, Craig Payne wrote:
| Quote: | It isn't too hard to make your own standard L's in 4 foot lengths with a
A request: Please don't attach several hundred K of pictures to your emails.
Email is not the way to send pictures around. You can post to the Matronics
forum and attach them there, without flooding people's email inboxes with
them. Thanks.
Jay Maynard, K5ZC http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
Fairmont, MN (FRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml
_________________ Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC |
Larry Hursh
Posted: Tue Oct 28, 2008 9:22 am Post subject: Re: Ch650 anti oil canning on 601 |
I have received the information from Travis at Zenith. (There isn't a photo - just info). According to Travis, here is what he said:
"Good morning Larry. I did a bit of checking and the 4' std. L can be cut in half for use between the ribs. They will run parallel with the main spar 425 center of rivet line to center of rivet line and are on the top skin only. So I figure you will need 6 4' L angles."
I will have two wing lockers so none is required in that bay, buy plan according if you don't have the lockers. I hope this helps everyone out.
Tailwinds and blue skies always,
