Ken
Posted: Sun Oct 26, 2008 6:43 am Post subject: Wiring |
I am an electronics hobbyist; therefore, I am not intimidated by the idea of wiring my XL. I still purchased the Homebuilt Help CD on wiring just to learn any peculiar aspects of aircraft wiring. On the CD they suggest a master breaker for the bus bar in addition to all the breakers that branch off of it. Its not a bad plan, but my concern is that if the breaker fails or trips, you loose everything over a single issue. I'm curious as how the rest of you dealt with this issue.
Ken
jaybannist(at)cs.com Guest
Posted: Sun Oct 26, 2008 7:03 am Post subject: Wiring |
Ken,
I see a master breaker as "double jeopardy." I don't see the need for one and I don't have one in my system. Most of my system goes through the battery contactor, but the endurance bus is wired (through a switch) directly to the battery.
Jay in Dallas
bryanmmartin
Posted: Sun Oct 26, 2008 7:11 am Post subject: Wiring |
I have my battery connected to my main fuse panel through the master
relay. I don't have a main breaker or fuse in that line, the master
relay is the only circuit protection for the battery cable. The
battery cables are secured and protected to prevent any chafing that
might cause a short. A short in the main battery cable will get your
attention very quickly, allowing you to interrupt the current with the
master switch. I don't see the need for a circuit breaker in addition
to the master relay. I do have a main fuse in the alternator cable
since it doesn't feed through the master relay. I have used aircraft
wiring throughout the cabin, in the case of a short circuit, the
insulation on this wire will not support combustion and will not give
off toxic fumes.
On Oct 26, 2008, at 10:43 AM, Ken wrote:
this issue.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
_________________ --
Bryan Martin
do not archive. |
Posted: Sun Oct 26, 2008 8:40 am Post subject: Wiring |
Have you looked at Bob Nuckolls' AeroElectric book? He is acknowledged as an
expert in this area and participates in an active forum of the same name on
Matronics.
http://www.aeroelectric.com/
The book is actually three-hole punched sheets. The appendix contains
schematics and the design rational for about 20 different situations.
As to your specific question Bob would probably recommend a fusible link for
your ultimate protection. But for safety your plane should be designed to be
flyable even if your battery/alternator were dead. I don't know what engine
you are looking at but with a traditional magneto your engine will run with
no battery power. For the auto conversions some go as far as to have two
batteries.
For instruments traditional gauges of course don't need power (day VFR). If
you chose a glass panel most of the manufactures have a provision for a
back-up battery.
-- Craig
Geoff Heap
Joined: 12 Jan 2006 Posts: 266 Location: Lindenwold, New Jersey
Posted: Sun Oct 26, 2008 2:06 pm Post subject: Re: Wiring |
The thing that’s confounded me for months is what kind of switch I need for a Master and what size fuse to go with it. Today I asked myself. Why do I even need it? I only have basic knowledge of how to make circuits work. Beyond that I have to seek help. So this thread has been illuminating for me. Ken points out that adding a fuse here is basically worthless and if faulty will lose you everything. I can now proceed. Thanks Guys…….Geoff
