jeff(at)westcottpress.com Guest
Posted: Fri Mar 17, 2006 9:08 am Post subject: AOA Provisions for Installation |
Builders,
I'm at the point in the construction of the outboard leading edge
where I have to decide if I'm going to install the conventional stall
warning device. Can anyone explain how the Angle of Attack indicator
works and what provisions have to made for it's installation.
Thank you,
Jeff Carpenter
40304
N410CF
rene(at)felker.com Guest
Posted: Fri Mar 17, 2006 9:58 am Post subject: AOA Provisions for Installation |
I did both, but because of the placement of the ports feel that you can wait
on making the AOA decision until later, so you have time to do some research
on the AOA. Here is my 1 minute explanation of my understanding.
The AOA uses two ports, one to top of the wing and one on the bottom of the
wing to sense local pressure. From these measurements, the AOA calculates
the angle of attack of the wing and thus gives you an indication of how
close you are to stalling.
Rene' Felker
rvbuilder(at)sausen.net Guest
Posted: Fri Mar 17, 2006 11:01 am Post subject: AOA Provisions for Installation |
Basically it uses differential pressure to calculate AoA. You can get more info from here: http://advanced-control-systems.com/AOAfaqs/aoafaqs.htm.
Also, you can get the wing kit for $400 so you can install that now and decide on which system later assuming you go with Rob Hickman's.
Michael Sausen
RV-10 #352 Working on Fuselage
zackrv8
Posted: Fri Mar 17, 2006 1:34 pm Post subject: Re: AOA Provisions for Installation |
Jeff,
The stall warning that Vans supplies is very basic. I wanted something better. The AOA system is much better. As you know, a wing only stalls when it exceeds it's critical angle of attack. An aircraft can be stalled at any speed and weight. The AOA will give you plenty of warning when approaching a stall whereas the stall warning horn that is supplied in the kit gives you a warning too close to a stall.
Remember, you will be hauling up to 4 people in your 10 so why not protect yourself and your passengers a little better? As you know, your stall speed changes with gross weight and CG loading. The AOA guage takes this into account and might just save your pink a$$ someday.
AOA is not for everyone. If you never used it, you probably won't see the need to fork out $1500 for one. However, If you have used one, and understand how it works....then it's hard to be without one.
My 10 will have the AOA Pro installed. I just installed the ports in the leading edge yesterday. Piece of cake. The tiny pin holes that you put in the wing look a lot better than that piece of metal sticking out of the leading edge.
Zack
_________________ RV8 #80125
RV10 # 40512 |
jjessen(at)rcn.com Guest
Posted: Fri Mar 17, 2006 2:12 pm Post subject: AOA Provisions for Installation |
One question that was raised in my mind one or two posts back was: Is there
any good reason to have both?
John Jessen
~328 (empennage)
Posted: Fri Mar 17, 2006 2:54 pm Post subject: AOA Provisions for Installation |
Probably a personal preference. Rob is supposed to have a profile for the RV-10 and will load it prior to shipping. You will still want to calibrate it to your aircraft when you fly though.
Anyway my point is the only reason I can think of to have both is when you are calibrating the AoA. Other than that the AoA should satisfy the regs as a stall warning device. I decided to not put in the Van's tab and riveted the two holes shut.
Michael Sausen
Posted: Fri Mar 17, 2006 3:14 pm Post subject: AOA Provisions for Installation |
My reasoning for two systems was simple, the Vans stall warning is simple,
mostly mechanical and easily tested during preflight. Where the AOA is a
much better "energy reserve" indicator, but more complicated and thus I
would think it was more susceptible to failure. Thus the vans stall warning
is a low tech backup.
Rene' Felker
RVFOURME(at)aol.com Guest
Posted: Sat Mar 18, 2006 1:31 am Post subject: AOA Provisions for Installation |
To all you industrious folks out there building RV-10's and interested in AOA instrumentation: Having built 2 RV-4's and not willing to shell out the money for a store-bought AOA, I made my own.................and it works fantastic !! It includes an aluminum wedge with a small .060 drilled hole on each face of the wedge to sense the difference of pressure, two lines going to the panel instrument and the instrument itself is a Dwyer meter which measures 1/2 inch of water column at full deflection. I will NEVER build another RV without having this instrument as my primary gauge for takeoff and landings. I don't even look at the airspeed indicator any more while in the pattern: it's irrelevant. Total cost for the homemade system? $100.00. Hope this can help all of you on a budget, as I always seem to be
Craig Ponnequin
sam.marlow
Posted: Sat Mar 18, 2006 8:04 am Post subject: AOA Provisions for Installation |
DO you have a web site describing installation? We need more info! Thanks,
Sam
Fuse
RVFOURME(at)aol.com (RVFOURME(at)aol.com) wrote:
Quote: | To all you industrious folks out there building RV-10's and interested in AOA instrumentation: Having built 2 RV-4's and not willing to shell out the money for a store-bought AOA, I made my own.................and it works fantastic !! It includes an aluminum wedge with a small .060 drilled hole on each face of the wedge to sense the difference of pressure, two lines going to the panel instrument and the instrument itself is a Dwyer meter which measures 1/2 inch of water column at full deflection. I will NEVER build another RV without having this instrument as my primary gauge for takeoff and landings. I don't even look at the airspeed indicator any more while in the pattern: it's irrelevant. Total cost for the homemade system? $100.00. Hope this can help all of you on a budget, as I always seem to be
Craig Ponnequin
Jerry Grimmonpre'
Joined: 09 Jan 2006 Posts: 144 Location: Huntley, Illinois 60142
Posted: Mon Mar 20, 2006 12:34 pm Post subject: AOA Provisions for Installation |
Hi Craig ...
You must be a rather smart dude to figure out an AOA instrument which works on Delta P. There are a bunch of
us who would like to know more about your homemade creation. Is it possible for you to share how you did it?
Regards ...
Jerry Grimmonpre'
RV8A
Huntley Illinois
Jerry Grimmonpre'
Posted: Mon Mar 20, 2006 12:59 pm Post subject: AOA Provisions for Installation |
Hi Craig ...
You are a smart dude to figure out an AOA instrument which works on Delta P.
I have a hunch there's are a bunch of us who would like to know more about
Regards ...
Jerry Grimmonpre'
RV8A
Huntley Illinois
