601xl aeilerons
K Dilks
PostPosted: Wed Oct 22, 2008 9:41 pm    Post subject: 601xl aeilerons Reply with quote
So following todays little flood of mails about the heavy ailerons , what if any mods have people done to make this easier?.
I flew a Tecnam JF 2002 at the weekend and the ailerons are the similar but with balance weight extending forward. I wonder why CH has not put this on and if it could be done so without great modifications.
Kit gets here 27november ........... Smile
Back home .................
psm(at)att.net
PostPosted: Thu Oct 23, 2008 2:09 am    Post subject: 601xl aeilerons Reply with quote
I think you are discussing two different problems rather than one.
The counter balance is probably there to prevent diverging mechanical
oscillation, known as flutter, that can destroy the plane. C. H.
designed his ailerons and all the control surfaces so they are not
prone to this problem. If you don't want to take my word for it, and
his, this is a wonderful area for extended discussion some other time.
Your point about "Fixing" the heavy ailerons is an interesting
one. It presumes there is something wrong with them the way they
are. I don't agree with this point of view. Let me explain . . .
The notion that there should be "Harmony" in airplane controls seems
to be an idea unrelated to the way real airplanes function and real
pilots fly. It seems to come from people who are better magazine
article writers than pilots and nearly always shows up in airplane
flight reviews. This is the notion that all three axis controls
should respond with similar movement to the same input
forces. Perhaps this is a big deal for aerobatic planes that get
jerked around in the sky, but for most planes it is not even an
issue. What is an issue is that the pilot can get the desired
aircraft response rather than some arbitrary control stick movement.
All planes respond to force applied to a control input with movement
around the indicated axis. It is this aircraft rotation response to
force that is important rather than its response to control
movement. In many planes and many control axes there is no
discernable movement at all of the control input device. This is the
case with the Zodiac aileron control.
Of course, the above is just my personal opinion. I expect there to
be disagreement on the harmony point. To give you a direct answer to
your question, I am not aware of anyone redesigning the controls on
any Zodiac to allow the stick to move more easily.
Paul
XL getting close
ideaz1(at)sbcglobal.net
PostPosted: Thu Oct 23, 2008 6:43 am    Post subject: 601xl aeilerons Reply with quote
No, not really... Heavy ailerons. Maybe there are 2
solutions (or many more).
oscillation, known as flutter, that can destroy the plane. C. H. designed
his ailerons and all the control surfaces so they are not prone to this
problem. If you don't want to take my word for it, and his, this is a
Sorry to sound argumentative, but the balancing of control surfaces is to
releive the control forces required. Just picture a much larger aircraft
with the same setup as the XL and you would have a hard time controling the
plane at all; and if I'm not mistaken we can discuss this any time we want.
Your point about "Fixing" the heavy ailerons is an interesting one. It
presumes there is something wrong with them the way they are. I don't
The notion that there should be "Harmony" in airplane controls seems to be
an idea unrelated to the way real airplanes function and real pilots fly.
It seems to come from people who are better magazine article writers than
pilots and nearly always shows up in airplane flight reviews.
GEES! I guess I never knew I wasn't a REAL pilot! Plus all the certificated
planes I have flown (knot realizing that I didn't know how) had quite well
balanced controls. Just take a look at the balance weights on a cessna some
time. And by the way I have yet to write a magazine article but apparently
those who have may want a word...
This is the notion that all three axis controls should respond with
similar movement to the same input forces. Perhaps this is a big deal for
aerobatic planes that get jerked around in the sky, but for most planes it
is not even an issue. What is an issue is that the pilot can get the
desired aircraft response rather than some arbitrary control stick
movement.
Maybe you don't think pilot fatigue is an issue but some of us do
around the indicated axis. It is this aircraft rotation response to force
that is important rather than its response to control movement. In many
planes and many control axes there is no discernable movement at all of
the control input device. This is the case with the Zodiac aileron
control.
What th...
Of course, the above is just my personal opinion. I expect there to be
disagreement on the harmony point. To give you a direct answer to your
question, I am not aware of anyone redesigning the controls on any Zodiac
Well, I am aware of people making mods. There is one XL recently completed
at my home airport with push-pull tubes rather than cables. I am not aware
of whether or how much improvement this makes as I have not flown that plane
but it is certainly part of the multiple solutions to this problem.Also the
first plane I built had a similar issue which was very successfully
corrected by moving the hinge point on the ailerons to balance the control
forces (by the way, this releives the force on every component from the
aileron all the way to the pilots shoulder!)
Dirk Z
Paul
XL getting close
brianrobertwood(at)gmail.
PostPosted: Thu Oct 23, 2008 8:17 am    Post subject: 601xl aeilerons Reply with quote
Maybe we are discussing one issue, but we are offering solutions that are
designed to address two issues that are quite distinct, control forces
and flutter. There are multiple ways to relieve the control forces,
including aerodynamic balance, balance tabs, spring tabs, weights, and
some others I can't remember at the moment.
Flutter is a complex phenonemon that is dependant on balance, speed,
elasticity, airflow, and probably a host of others that I don't know about
(I am no engineer). It is often overcome by use of balance weights, as
well as careful engineering.
Brian in Brazil
Gig Giacona
PostPosted: Thu Oct 23, 2008 8:31 am    Post subject: Re: 601xl aeilerons Reply with quote
[quote="ideaz1(at)sbcglobal.net]Sorry to sound argumentative, but the balancing of control surfaces is to
plane at all; ...[/quote]
http://members.eaa.org/home/homebuilders/building/controls/Control%20Surface%20Balancing%20in%20Homebuilts.html?
Control Surface Balancing in Homebuilts
Sport Aviation - 12/96
By Tony Bingelis
The obvious question comes to mind. Why balance control surfaces? Do they really need to be balanced?
Well, much seems to depend on the original design and construction of the control surfaces. Well-designed, rigid structures with little or no play in the hinges, control linkages, and trim tabs are less likely to be susceptible to flutter, hence, may not need to be statically balanced.
W.R. "Gig" Giacona
601XL Under Construction
psm(at)att.net
PostPosted: Thu Oct 23, 2008 8:46 am    Post subject: 601xl aeilerons Reply with quote
Hi Brian,
Thank you for your comment. I think your point of view is very
valuable. These issues are related but only distant relatives.
This thread started as a discussion of heavy aileron forces on a demo
flight. The counterbalances were added as a possible solution for
the heavy controls. My last comment was to try to separate the
counterbalances from the heavy controls, but your take on this issue
seems like it is more clear.
I want to try again to distinguish the heavy control issues without
regard to flutter.
If you move the stick left and right on the ground, it takes a
significant amount of force to go from one limit to the other. I
submit this is a minor issue.
In the air, when you apply a side force to the stick the plane rolls
very nicely. However, the stick doesn't move much at all in this
case. For a pilot who gets his control feedback from the plane's
roll attitude this is not an issue. For a different pilot who
ignores the plane's attitude and only considers how far the control
stick moves this is a problem. I submit that a pilot should gauge
his actions by the response of the plane's attitude rather than the
movement of the stick.
Best regards,
Paul
XL getting close
Brian in Brazil
psm(at)att.net
PostPosted: Thu Oct 23, 2008 8:57 am    Post subject: 601xl aeilerons Reply with quote
Hi Gig,
I'm confused by your post.
In the first part you say balancing control surfaces is done to
relieve control pressures. In the second part you quote Bingelis
saying you only need to do this to reduce tendency for flutter.
In the aileron case, when you move the stick one aileron goes up and
the other goes down. This naturally provides balance from the
control stick's point of view. It is true no matter how big the
plane is. Said another way, the opposite aileron acts as a counter
balance. This addresses the control balance issue without
considering the flutter issue which, I believe, is more of a single
control surface issue and requires the local counterbalance you see
on many higher performance planes.
This is different from the elevator case where there is only one
moving control surface. The bigger the elevator the more effort it
takes, on the ground, to raise it. In the air, I submit it is the
airflow over the elevator and how much this is disrupted by a stick
movement that determines how much force is applied to the pitch axis
of the plane and how much feedback is applied to the stick. The
large forward movement of the plane along with the elevator trim
keeps the elevator centered before moving the stick. Still, a
counterbalance might be installed to reduce flutter tendencies in the
elevator in some designs.
Paul
XL getting close
plane at all; ...
By Tony Bingelis
W.R. "Gig" Giacona
[/quote]
jimandmandy(at)yahoo.com
PostPosted: Thu Oct 23, 2008 9:55 am    Post subject: 601xl aeilerons Reply with quote
I have made demo flights in three different 601XL aircraft, two Continental powered and one Corvair. My previous experience is mostly C-152's, but also a few hours in the Tomahawk, Diamond Katana and Sonex. My impression of the 601XL is yes, roll control feels a little heavy, but I do not see this as a problem. It took only a few minutes to become familiar with it.
Even large certified transports, such as fly-by-wire Airbus', do not necessarily have equal or even linear control forces in all axes.
Jim LoBue
601XL/Corvair
--- On Thu, 10/23/08, Paul Mulwitz <psm(at)att.net> wrote:
[quote]From: Paul Mulwitz <psm(at)att.net>
Subject: Re: 601xl aeilerons
Date: Thursday, October 23, 2008, 9:44 AM
[quote]--> Zenith601-List message posted by: Paul Mulwitz <psm(at)att.net>
Hi Brian,
regard to flutter.
Best regards,
Paul
XL getting close
[quote]>>I think you are discussing two different problems rather than one.
and flutter. There are multiple ways to [quote][b]
jaybannist(at)cs.com
PostPosted: Thu Oct 23, 2008 11:44 am    Post subject: 601xl aeilerons Reply with quote
To add to what Gig and Tony Benglis say, I think that nearly all "add-ons" (such as balance weights, VGs, etc.) are to overcome a not quite perfected design. Granted, airplane design is really part science, part art. There is ample evidence that not all aeronautical engineers are skillful at blending all the requirements into a fully complete design that requires no "add-ons". Chris Heintz has been designing airplanes for a LONG time. I fully trust him and believe that if he thought aileron balance weights or VGs were necessary, they would have been there.
Jay in Dallas
daveaustin2(at)primus.ca
PostPosted: Thu Oct 23, 2008 3:51 pm    Post subject: 601xl aeilerons Reply with quote
Just a thought..
You could not break the aeroplane with the way the ailerons are by design,
at any speed, but you could very easily break it with the sensitive
elevators at higher speeds. However, you don't need to have more sensitive
ailerons for control at any speed, but you certainly need sensitive
elevators at low speed.
I think that's why Chris designed it the way it is.
Solution is, install roll trim. I have and have flown many long flights
without any tiring effect.
Dave Austin 601HDS - 912
Gig Giacona
PostPosted: Fri Oct 24, 2008 7:25 am    Post subject: Re: 601xl aeilerons Reply with quote
No you are confused by the screwed up quotation of the post I was responding to.
It is my position that the balancing is used to reduce flutter because Bingelis said so.
psm(at)att.net wrote:
Hi Gig,
W.R. "Gig" Giacona
rpf(at)wi.rr.com
PostPosted: Fri Oct 24, 2008 8:01 am    Post subject: 601xl aeilerons Reply with quote
I have to agree with Dave. I have hingeless ailerons (which I'm sure are
stiffer than hinged ailerons) and have flown my XL on a number of cross
country flights, the longest being Wisconsin to California, and the flight
was not fatiguing at all.
Just telling real life experiences.
Randy 601XL - Jabiru 3300
