Flap root extensions
jpg12305
PostPosted: Thu Oct 23, 2008 11:29 am    Post subject: Flap root extensions Reply with quote
Hi there,
When I bought my Europa Classic two years ago it was "delivered" without the flap root extensions fitted.
The baby flies smoothly, while I suspect some undesirable drag generated by the gaps between flaps and fuselage, not talking about the fact it is unaesthetic.
In the bunch of materials and parts inherited from the previous owner I found the relevant foam cores, and I think it's time to correct this and retrofit the extensions. Busy winter ahead !
The manual is not so clear about the process and any advice or pictures will be therefore warmly welcome.
Jean-Paul
Monowheel #332
grahamsingleton(at)btinte
PostPosted: Thu Oct 23, 2008 1:39 pm    Post subject: Flap root extensions Reply with quote
jpg12305 wrote:
Hi there,
Jean-Paul
Monowheel #332
Jean-Paul
some pix for you to look at. You should also look at Justin Kennedy's
and Fred Klein's design. Very nice
Graham
 Filesize:  284.35 KB
 Viewed:  302 Time(s)
 Filesize:  143.63 KB
 Viewed:  323 Time(s)
 Filesize:  206.89 KB
 Viewed:  315 Time(s)
 Filesize:  212.05 KB
 Viewed:  308 Time(s)
