rotax wiring
ruruny(at)aol.com
PostPosted: Tue Oct 21, 2008 6:09 pm    Post subject: rotax wiring Reply with quote
Geoff,
Once you crimp the connector on the wire, I added a dab of solder, you can insert it into the connector without taking
it apart. It will snap in place just make sure you have it all ready, it will be hard to take it out. Don't forget to slide the
grommet over the wire first before crimping.
http://701builder.com/rotaxignitionwiring.html
Brian
Geoff Heap
PostPosted: Fri Oct 24, 2008 2:54 am    Post subject: Re: rotax wiring Reply with quote
Thanks Brian.
Boy, the list is dead lately. Only concrete answer I've got. No answer on the Rotax list at all.....Geoff
bobkat
PostPosted: Fri Oct 24, 2008 4:15 am    Post subject: Re: rotax wiring Reply with quote
Geoff's pictures were great and explained it well, Brian. I had just replaced the two plugs on a 912 I have on a Kitfox and wish I'd seen his pictures before ti tackled the job.
My 912 S came already wired and ready to go though. The rest of the rest of the wiring I got right out of the Installation manual and Dynon Instruction book. Pretty straight forward.
Bob
Geoff Heap
PostPosted: Fri Oct 24, 2008 4:46 am    Post subject: Re: rotax wiring Reply with quote
I'm Geoff. I had the question. Brian is the Guy with the first class photo's. Give him the credit, not me..............Geoff
Working on the Electrical. Rotax80hp/Dynon D180/Garmin 296/Icom AC-A210/Dual controls/Becker transponder. Electronics Fool
EricWalker
PostPosted: Fri Jan 10, 2020 5:35 am    Post subject: Re: rotax wiring Reply with quote
An electronics and all motives of the joyful men’s are struck for the individuals. The aspects of the ‌‌zip job review are vital for the futurisms. The structure is reformed for all joys. Matter is invited for the injunctions. Proportion of the manual script is written for the futurisms. the reign is filled for the automatic means for humans.
