Posted: Mon Oct 20, 2008 12:52 pm Post subject: Van's strobe bracket |
Has anyone used the Van's strobe bracket with the Creative Air C Avi Flash Strobe power supply. Is the hole pattern the same or will i need to make a plate that interfaces the two.
Any reason to use the Whelan power supply over the Avi Flash other than the fit...the Avi Flash is $120 less $$$$.
Thanks C
JOhn Gonzalez
rv10(at)sinkrate.com Guest
Posted: Mon Oct 20, 2008 2:03 pm Post subject: Van's strobe bracket |
I bought one of these. It mounted to the van’s strobe bracket w/o modification. I’m not flying yet nor have I tested the unit.
http://www.strobesnmore.com/nova-x-pak-strobe-power-supplies.html
By the same argument of price I’m wondering why one would use the creative air supply either? It’s nearly $300 where the Nova supplies are usually half that. There are even cheaper units available… sub $100 that would probably work fine.
-Ben
John Gonzalez wrote:
Has anyone used the Van's strobe bracket with the Creative Air, Avi Flash Strobe power supply. Is the hole pattern the same or will i need to make a plate that interfaces the two.
JOhn Gonzalez
__________ Information from ESET NOD32 Antivirus, version of virus signature database 3538 (20081020) __________
The message was checked by ESET NOD32 Antivirus.
MauleDriver(at)nc.rr.com Guest
Posted: Mon Oct 20, 2008 2:12 pm Post subject: Van's strobe bracket |
I used the Van's bracket with the Avi Flash Strobe. I don't recall having to do anything other than screw it on. No plate requiired.
In retrospect, I would have mounted it as far forward in that bay as possible to give maximum distance from the projected mounting of my GRT Magnetometer - but it's ok centered in the bay too.
John Gonzalez wrote: [quote] .hmmessage P { margin:0px; padding:0px } body.hmmessage { FONT-SIZE: 10pt; FONT-FAMILY:Tahoma } Has anyone used the Van's strobe bracket with the Creative Air, Avi Flash Strobe power supply. Is the hole pattern the same or will i need to make a plate that interfaces the two.
JOhn Gonzalez
| [b]
daveleikam(at)wi.rr.com Guest
Posted: Mon Oct 20, 2008 2:19 pm Post subject: Van's strobe bracket |
The holes are the same, you just need to install nut plates which I believe are included with the bracket.
Dave Leikam
RV-10 #40496
N89DA (Reserved)
Muskego, WI
