tomcostanza
Posted: Sun Oct 19, 2008 12:18 pm Post subject: Wing-to-Fuselage electrical connections |
Gentlemen,
I'm at a point where I need to decide how to connect wires in the wing, to the corresponding wires in the fuselage. For DC stuff, I had planned to use the wiring connectors one often sees connecting a trailer to a truck (and as seen on aeroelectric.com). I'm now thinking that since I will need to splice these connectors into the wiring anyway (2 splices for each wire), I might as well just splice the WIRES together and eliminate the connector (1 splice per wire). But I'm using wingtip nav antennas, and I'm wondering whether to use BNC connectors or splice the coax. I don't know which will create more of an impedance mismatch or RF loss, but I'm thinking for a receiver, it doesn't make a whole lot of difference. What do you think?
_________________ Clear Skies,
Tom Costanza
-- in year 17 of a 3 year project |
Posted: Sun Oct 19, 2008 2:51 pm Post subject: Wing-to-Fuselage electrical connections |
Posted: Sun Oct 19, 2008 2:53 pm Post subject: Wing-to-Fuselage electrical connections |
Tom
This is not an answer to your question, because I don’t know it. I will be another one to profit from the responses you will get, because I didn’t make those connections either.
By the way, you are talking about “wingtip nav antennas”, how many did you install, and which type are they?
Carlos
[quote] --
rjquillin
Posted: Sun Oct 19, 2008 4:37 pm Post subject: Wing-to-Fuselage electrical connections |
At 15:52 10/19/2008, you wrote:
| Quote: | But I'm using
do you think? |
Only one mans' opinion Tom, but given the choice of "splicing" coax or using a pair of connectors; for me it's an absolute brainer. Connectors, by all means. Minimum signal loss due to impedance mismatch and contiguous shield to prevent unwanted signal ingress. And given proper connectors much simpler and faster to reliably terminate.
Ron Q. [quote][b]
nuckolls.bob(at)cox.net Guest
Posted: Sun Oct 19, 2008 5:04 pm Post subject: Wing-to-Fuselage electrical connections |
At 01:19 PM 10/19/2008 -0700, you wrote:
<Tom(at)CostanzaAndAssociates.com>
Gentlemen,
do you think?
The airplanes I fly are on average, 15+ years old.
I'll bet not a one of them has ever had the wings off.
If I were building an airplane, wings would be wired as
they are built and 10' or so pigtails left at the fuselage
end coiled up for later routing into the fuselage and
attachment to their respective destinations . . .but
with a "service loop" about 4-6" in diameter (12-18"
of slack wire) under the wing root fairing.
Should it become necessary to EVER remove the wings,
then cut wires and/or coaxes in the middle of their
service loops. When replacing the wings, permanent
splices (and mated coax cable connectors)
http://www.aeroelectric.com/Pictures/Connectors/Coax/BNC_Cable_Female_1.jpg
or
http://www.aeroelectric.com/Pictures/Connectors/Coax/BNC_Bulkhead_Female.jpg
and
http://www.aeroelectric.com/Pictures/Connectors/Coax/BNC_Cable_Male.jpg
are in order for re-attaching the wings and associated
wiring.
For permanent splices, these critters are certainly
an option . . .
http://aeroelectric.com/Pictures/Terminals/PIDG-Splices.jpg
these are also favored by the grey beards for
closing cut lines but leaving a service connection
behind . . .
http://aeroelectric.com/Pictures/Terminals/ksplc2.jpg
If you wanted to use one one of these style
connectors
http://aeroelectric.com/articles/wingwire/wingwire.html
you could also consider this technique for making
high-quality, permanent splices of ship's wiring
to the connector's pigtails . . .
http://aeroelectric.com/articles/Solder_Lap_Splicing/Solder_Lap_Splices.html
Inclusion of a "service loop" of excess wire at
time of original fabrication allows for a dozen or
more cut-out-and-replace operations on individual
wires over the lifetime of the airplane.
Finally, I had a chance to fiddle with these
connectors while wiring Ol' Blue (My hand-me-down
'87 Jimmy) to tow a trailer. This was the first
time I'd put my hands on this combination of
connectors:
http://www.aeroelectric.com/Pictures/Connectors/Power/Trailer_Lights_Plug.jpg
http://www.aeroelectric.com/Pictures/Connectors/Power/Trailer_Lights_Jack.jpg
This mated pair of connectors offers some interesting
design features. The male pins in the jack are solid
bifurcated brass that plug into seamless tube sockets
in the plug housing. The spring loaded lid has a retaining
dog that holds the plug engaged the jack. These are only
slightly heavier than their mil-spec counterparts and
they're a whole lot cheaper. The only disappointment was
the wire attach methodology that runs a screw thread down
against the wire strands.
I installed wires by cutting 2x long, folding the strands
back and soldering them such that they became a solid, solder
encased "plug". run the screw down against the plug nice and
tight and follow up with an encapsulation of E6000 not unlike
what we did here
http://aeroelectric.com/articles/macservo/macservo.html
to deal with those pesky little 26AWG wires on a RayAllen
actuator.
The wiring jack can probably be mounted to fuselage skin
tomcostanza
Posted: Mon Oct 20, 2008 4:36 am Post subject: Re: Wing-to-Fuselage electrical connections |
| Quote: | | By the way, you are talking about “wingtip nav antennas”, how many did you install, and which type are they? |
Carlos,
I'll be installing the Bob Archer nav antennas (one in each wingtip) for a VOR/LOC antenna, and using a diplexer to feed the glide slope.
| Quote: | If I were building an airplane, wings would be wired as
of slack wire) under the wing root fairing. |
Bob,
Thanks. In a perfect world, I would do the same. However, I'm trying to do as much as possible in the shop. I feel I can do a better job when I have as much heat, light, and tools as I need. So I'm going to wire everything I can before moving to the airport. Hopefully, I can just bolt the wings, empenage and fairings on and be done. I'm not even sure I'll have a hangar available. Even if I do have a hangar, the cost is more than a BMW car payment each month, so I'd like to minimize the time I rent it.
So it's looking like I'll use BNC connectors for the coax, and splice the DC wires, with a DB-9 for the Ray Allen vermicelli.
Thanks again to all.
Tom Costanza
Flagstone(at)cox.net Guest
Posted: Tue Oct 21, 2008 10:54 am Post subject: Wing-to-Fuselage electrical connections |
What are the thoughts on using MOLEX connectors?
rv9jim(at)juno.com Guest
Posted: Tue Oct 21, 2008 2:02 pm Post subject: Wing-to-Fuselage electrical connections |
At 11:52 AM 10/21/2008 -0700, you wrote:
Molex makes a raft of different connectors but
I presume your talking about white nylon critters
that look like these:
http://aeroelectric.com/articles/matenlok/matenlok.html
Waldom/Molex and Tyco/AMP both have variations
on this theme of power connectors. The Mate-n-Locks
were incorporated into the single-engine airplanes
at Cessna while I was still in their employ . . .
about 1968. As far as I know, there were no big
service issues that popped up resulting from
utilization of these connectors.
marcausman
