Subject: Prestart warm up question
kissell
PostPosted: Mon Oct 20, 2008 12:52 pm    Post subject: Subject: Prestart warm up question Reply with quote
Subject: "Prestart warm up question"
I live in Dayton Ohio where a warm up is required in the winter months. I purchased a small construction heater, the type that uses kerosene as fuel and has a forced air burner that sounds like a small jet engine. I fabricated a flange with an adjustable air space that transitions the heater output to a flexible aluminum hose that I direct upwards around the muffler and cowl opening. I open the oil door to provide an air path for the heat to flow up and out. I have found that this system works well and heats the engine quickly even on a really cold day. It's also great to warm up the pilot while waiting..
Bob Kissell N701UB
