planesmith(at)hotmail.com Guest
Posted: Mon Oct 20, 2008 10:39 am Post subject: Aftermarket wishlist (was RV10 Axle Extensions) |
Tim & Don C
What I would like to see is a cap and shaft arrangement similar to the Cessna 150 front axle. The two caps take the place of the aluminum spacers we use but fit over the shaft end and are captured by the axle bolt. Bearing pre-load is set by using different thickness spacers.
A retro fit kit would consist of a shorter than stock shaft C two end caps and some spacers.
Vern Smith (#324)
> Date: Sun C 19 Oct 2008 12:12:48 -0500
[quote] spacers on the front axle. If only someone (maybe you're
up for it??) came up with a good retrofit kit that included
anti-rotation stop screws
Store C manage and share up to 5GB with Windows Live SkyDrive. Start uploading now
