daveleikam(at)wi.rr.com Guest
Posted: Mon Oct 20, 2008 5:59 am Post subject: Grounding |
When should you ground components locally and when should you ground to the battery directly?
Flap motor? Lights? Pitot heat? Defrost fans, and the like?
Dave Leikam
RV-10 #40496
N89DA (Reserved)
Muskego, WI
nuckolls.bob(at)cox.net Guest
Posted: Mon Oct 20, 2008 7:14 pm Post subject: Grounding |
At 08:57 AM 10/20/2008 -0500, you wrote:
Quote: | When should you ground components locally and when should you ground to
Nothing grounds directly to the battery. The battery
and all things local to the panel and engine should
go to a single point ground on the firewall. See View -A-
of figure 15 of:
http://aeroelectric.com/articles/Rev11/AppZ_R11M.pdf
Stuff away from the panel like landing lights, strobe
supplies, position lights and pitot heat can ground
locally to structure.
Also see photos of grounding accessories at:
http://aeroelectric.com/Pictures/Grounding/
Posted: Tue Oct 21, 2008 4:14 am Post subject: Grounding |
Thanks, I should have rephrased battery to mean single point ground.
Dave
AV8ORJWC
Posted: Tue Oct 21, 2008 8:54 am Post subject: Grounding |
The subject of single point ground is an interesting one. I think the
world of Bob's contribution to aircraft electrical wiring yet, the
SFAR88 issue (for the airlines) is an attempt by the FAA to quash those
of us that believe the US Navy actually brought down TWA 800 not a bad
single point ground using WWII wiring schemes.
There are many points covered in SFAR88 but one is a direct effort to
avoid single point grounds for electrical devices in proximity to
hydrocarbons. It makes for an interesting consideration. Till then,
this is still the best place to gain knowledge on wiring kit built
aircraft and enjoying their flight characteristics.
Like Bob says, They are not equal, they are better than certificated
production units.
John
Do not Archive
longg(at)pjm.com Guest
Posted: Tue Oct 21, 2008 10:09 am Post subject: Grounding |
Myself as well as many other builders in my area have simply used the B
& C grounding block. It's a thing of beauty. 48 inside and 24 on the
firewall. If that doesn't cut it, better to chat with Boeing on that
SFAR88 thingy.
Kudos to B & C for coming up with a simple but elegant solution to
grounding.
Yes, unless it's a 59' Plymouth with one of those Morse code looking
regulators, don't run grounds to the battery.
Posted: Tue Oct 21, 2008 2:04 pm Post subject: Grounding |
SFAR88 thingy.
grounding.
That's a product we developed here and sold for a time
before turning it over to B&C. We're going to be offering
a panel-ground concentrator block in the near future.
It will look like this:
http://aeroelectric.com/Pictures/Grounding/AVG_RA.jpg
We're looking at a more compact version of the forest-
of-ground-tabs too, but that one is not a done deal
yet.
Posted: Thu Oct 23, 2008 6:43 am Post subject: Grounding |
Very nice,
I'll buy two.
