rv9jim(at)juno.com Guest
Posted: Fri Oct 17, 2008 7:04 am Post subject: Wheel Bearings |
With the bearing part numbers, you can get them at any "Bearing house".
I am a bearing house located in central Florida so if you can not find
anyone, give me a shot.
Jim Nelson
Terry Bearing Co.
727-541-5527
RV9-A
Click for free info on college degrees.
http://thirdpartyoffers.juno.com/TGL2141/fc/Ioyw6i3l8Wv0i7ZkSQqp4cnEZKkDhIwNT5oBIYXr2s7k8nchjoTveT/
Posted: Fri Oct 17, 2008 7:57 am Post subject: Wheel Bearings |
When dealing with wheel bearings, there are two types. The main gear
would be taper roller style. Cup and cone. The parts have two different
part numbers so if you pull your wheels and the cones fall in your hand,
that will have one part number. The cup (outer race inside the wheel
hub) will have a different part number. You will have to knock out the
race to see the part number of the outer race. Tail wheels usually have
ball style bearings. Those usually are mounted in a one piece bearing
with a retaining ring on the outside to keep the bearing from falling
into the hub. That said, some tail wheels also have taper roller
bearings.
Jim Nelson
Terry Bearing Co.
RV9-A
Live the good life! Click now for great retirement planning assistance!
http://thirdpartyoffers.juno.com/TGL2141/fc/Ioyw6i3mK7Brn80lxadQJrr86iaqaW2QhF5vlZzeaeT5yD1l5qVnwH/
