z601(at)anemicaardvark.co Guest
Posted: Fri Oct 17, 2008 8:11 am Post subject: props |
I'm trying to plan ahead a bit, while waiting for the z601XL kit to be
available for pickup at Zenith's facility. One of the things on my shopping
list is a prop.
I've got an O-200A that I'm overhauling, and I need a prop to mate with it for
the 601XL. My current thinking is that:
1) I don't want to use a metal prop because of weight.
2) It may be desirable to use a ground-adjustable prop so I can tweak the
pitch for max performance consistent with LSA requirements.
While the lower weight of a wood or composite prop is desirable, it may also
shift the weight and balance envelope too far aft. What has been experienced
in this area?
And, in general, what are others using and experiencing? Are there any of the
homebuilt prop companies which seem particuarly good or particular bad, and
should be avoided? Your comments are solicited. Thanks.
Those who can, do. Those who can't, sue.
Jim B. Belcher
BS, MS Physics, math, Computer Science
A&P/IA
Instrument Rated Pilot
General Radio Telephone Certificate
| - The Matronics Zenith601-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
psm(at)att.net Guest
Posted: Fri Oct 17, 2008 8:33 am Post subject: props |
Hi Jim,
I would suggest you plan to use a wood prop. I am using one from
Sensenich for my XL, but it was chosen by the folks that put together
a FWF for my Jabiru engine. Rumor has it this particular prop works
very well on the XL while the Sensenich composite ground adjustable may not.
Your engine is one of the heaviest ones that will work in the Zodiac
XL. That means your weight and balance problem will likely be too
much weight up front rather than too little.
You might be able to use one of the ground adjustable pitch props
available since you have only 100 HP. There are several choices with
100 HP as their upper limit.
One of the advantages of wood props is they are low enough in price
that you can plan to have a few different ones over time. Indeed you
will need to replace them much faster than a metal prop.
Good luck,
Paul
XL getting close
list is a prop.
with it for
in this area?
Gig Giacona
Posted: Fri Oct 17, 2008 8:37 am Post subject: Re: props |
With an O-200 I don't think you will ever need to concern yourself with the CG being too far backwards because of a prop.
If you are going to keep your plane inside a hanger most of the time, rarely fly in the rain and not land off airport too often go with wood. It looks better. If not go with a Warp Drive or Sensnich composite.
z601(at)anemicaardvark.co wrote: |
in this area?
601XL Under Construction
ideaz1(at)sbcglobal.net Guest
Posted: Fri Oct 17, 2008 8:56 am Post subject: props |
Check out the IVO prop. I had a 3 blade elec. adjust (in flight adjustable)
and it was GREAT! Excelent climb and then set for your cruise. Easy to use.
I don't know what the legality is since you cannot have in-flight adjust
under sport pilot rules. You should check if you do the initial registration
in that configuration can you remove the elec. adjust later to be legal
under sport OR do you register it without the elec. motor on, then add it
later so it can then be removed if you fly under sport rules???
At any rate the 3 blade elec adjust for the O-200 is a few lbs. lighter
than metal even with the elec adjust but the extra weight is at the hub so
the prop will still spin up faster than aluminum.
You can also remove one blade If one gets damaged and fly home on 2. OR
just fly on 2 blade prop, slightly less climb and slightly faster cruise
this way.
I'm not connected with IVO, just used one on a 2 place ultralight and was
very pleased with the performance.
Dirk
jmaynard
Joined: 27 Feb 2008 Posts: 394 Location: Fairmont, MN (FRM)
Posted: Fri Oct 17, 2008 9:17 am Post subject: props |
On Fri, Oct 17, 2008 at 11:11:13AM -0500, Jim Belcher wrote:
Quote: | And, in general, what are others using and experiencing?
For completeness' sake, AMD is using a Sensenich wood-composite prop with
the O-200. CG has never been an issue for me.
Jay Maynard, K5ZC http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
Fairmont, MN (FRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC
_________________ Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC |
jimandmandy(at)yahoo.com Guest
Posted: Fri Oct 17, 2008 9:18 am Post subject: props |
The AMD factory built 601/650 has a wood Sensenich fixed pitch prop and O-200A. Using the same one might get you a 25hr instead of 40hr flight test period.
--- On Fri, 10/17/08, Jim Belcher <z601(at)anemicaardvark.com> wrote:
[quote]From: Jim Belcher <z601(at)anemicaardvark.com>
Subject: props
Date: Friday, October 17, 2008, 9:11 AM
[quote]--> Zenith601-List message posted by: Jim Belcher
list is a prop.
it for
in this area?
Jim B. [quote][b]
Gig Giacona
Posted: Fri Oct 17, 2008 11:05 am Post subject: Re: props |
I asked the FSDO in writing about that prop and LSA. Big NO. I even asked if it would be legal if the in-flight adjustable feature were disabled and could not be activated in the cockpit. Like a switch in the wire under the cowl that could turn the adjustment ability on for a non-LSA pilot and off when an LS pilot was flying. Again a big NO.
ideaz1(at)sbcglobal.net wrote: | Check out the IVO prop. I had a 3 blade elec. adjust (in flight adjustable)
this way.
Dirk |
planecrazydld(at)yahoo.co Guest
Posted: Fri Oct 17, 2008 12:15 pm Post subject: props |
...and the natural damping of the wooden prop is an asset to both the airframe and the engine.
David L. Downey
Harleysville (SE) PA, USA
--- On Fri, 10/17/08, Gig Giacona <wrgiacona(at)gmail.com> wrote:
[quote]From: Gig Giacona <wrgiacona(at)gmail.com>
Subject: Re: props
Date: Friday, October 17, 2008, 12:37 PM
[quote]--> Zenith601-List message posted by: "Gig Giacona"
fly in the [quote][b]
Posted: Fri Oct 17, 2008 6:45 pm Post subject: props |
You can still install this prop as ground ajustable and add the elec. motor
later.
Quote: | I asked the FSDO in writing about that prop and LSA. Big NO. I even asked
chris Sinfield
Joined: 28 Nov 2006 Posts: 270 Location: Sydney Australia
Posted: Sat Oct 18, 2008 7:37 pm Post subject: Re: props |
Dont tell me this Paul as I just bought the ground adjustable one. I thought it was OK with the Jab USA FWF kit from Pete..
Chris
Posted: Sat Oct 18, 2008 7:49 pm Post subject: props |
It is not a rumor but not as bad as Paul says. On one of the FWF DVDs Pete
says something like "the adjustable prop is nice but it will cost you 2 or 3
knots"
My feeling is that since you can adjust it you will be able to make the
adjustable prop fit your flying goals better than a fixed wooden prop.
-- Craig
Posted: Sat Oct 18, 2008 10:34 pm Post subject: props |
Hi Chris,
Actually it was Pete that told me it didn't work well, so he sold me
the wood prop when I bought the engine and FWF from him.
Paul
At 08:37 PM 10/18/2008, you wrote:
Quote: |
<chris_sinfield(at)yahoo.com.au>
Chris
lwhitlow
Joined: 15 Jan 2006 Posts: 76 Location: Valparaiso Indiana
Posted: Sun Oct 19, 2008 4:34 am Post subject: Re: props |
Oh Man I hope not
I bought the Carbon Fiber Ground Adjustable right from Jabriu and nobody said a word.
I went that way because of weight on the nose I'm using the Jab 3300 and I wanted to shave a few pounds up front so I didn't have to put the battery behind the seat
Oh well Its in the box and it's going on the front!!!
OK OK maybe I should mount the engine first! That's next months job.
Larry Whitlow
psm(at)att.net wrote: | Hi Chris,
Paul
Quote: |
<chris_sinfield>
Chris
tonyplane(at)bellsouth.ne Guest
Posted: Sun Oct 19, 2008 8:47 am Post subject: props |
Last year and over 100 flight hrs ago, my wife bought me a ground adjustable
prop for my XL. I hung my wood Sensenich W64ZK51 on the wall - it still
looks new!
My opinion - The Sensenich EZ Pitch Composite, P/N 2AOJ5R64ZN, is great on
my XL. I have it pitched for climb out of my farm field (need it! -
Tennessee trees are not the FAA "standard 50 ft" ones). My XL has 6x600
wheels/tires all around, so it is a little more draggy than a standard XL.
I can not be sure, but it does seem to be a little smoother than the wood
one.
I did lose about 2 - 3 kts in cruise at the same rpm, but I can get up
faster. Would do it again.
Tony Graziano
Zodiac 601XL/Jab3300A; N493TG; 432 hrs
Posted: Tue Oct 21, 2008 11:09 am Post subject: props |
Thanks for all the input from everyone on props. It does not sound as though I
will have a weight and balance issue. For my application, it appears the
choice remains between ground adjustable and fixed pitch wood.
I'll get some prices, and see if I can afford the adjustable. If I can't, I'll
see if I can get one of the experimental shops to clone the Sensenich wood
fixed pitch prop.
Incidently, it may just be my background, but I've never considered not having
at least a 40 hour test period. Thus, a certified engine/certified prop
combination has never been a consideration to me.
Jim B. Belcher
A&P/IA
Gig Giacona
Posted: Tue Oct 21, 2008 1:02 pm Post subject: Re: props |
fixed pitch prop.
Why not just have Sensenich make you one? My custom prop (which spins the wrong way) was a little under $800.
Posted: Tue Oct 21, 2008 1:16 pm Post subject: props |
On Tuesday 21 October 2008 16:02, Gig Giacona wrote:
Quote: | Why not just have Sensenich make you one? My custom prop (which spins the
That's cheaper than I would have expected. I'll consider them.
Jim B. Belcher
A&P/IA
Posted: Tue Oct 21, 2008 1:19 pm Post subject: props |
Hi Jim,
Why not get Sensenich to make you the prop you need. The one I got
for the Jabiru (64ZK49, I think) was around $600. It has a nice
plastic leading edge and seems like a good deal to me. I have
exchanged emails with the guy at Sensenich and believe he will
probably be happy to supply your prop. If you have trouble finding
the right contact (try Google) let me know and I will find my old email.
Good luck,
Paul
At 12:09 PM 10/21/2008, you wrote:
as though I
can't, I'll
fixed pitch prop.
not having
Jim B. Belcher
A&P/IA
Gig Giacona
Posted: Wed Oct 22, 2008 8:24 am Post subject: Re: props |
In all seriousness if I found a prop maker that would custom build a wooden prop for less than Sensenich did there is no way I fly behind it.
I checked my records and the exact price was $725 + $26 shipping for my 64x43 prop. I ordered mine in February of this year and got it about 11 week later.
Just for fun do three Google searches and look at the hit counts at the top of the page and then think how long Sensenich has been building props and how many are out there as opposed the others.
IVO Prop Failure
Warpdrive Prop Failure
Sensenich Prop Failure
z601(at)anemicaardvark.co wrote: | On Tuesday 21 October 2008 16:02, Gig Giacona wrote:
That's cheaper than I would have expected. I'll consider them. |
Posted: Wed Oct 22, 2008 8:51 am Post subject: props |
There supposedly are some good non-certificated prop makers out there. At one
time, one lived in my area (about 30 miles from here, near Marfa, Texas). His
props were legendary, but he's long since deceased, or I'd at least pay him
a visit.
But, as I think you are suggesting, there is some bottom line price at which
one can make a quality prop (or anything else, for that matter). I suspect
the numbers you quote from Sensenich are at or near that value.
Quote: | I checked my records and the exact price was $725 + $26 shipping for my
week later.
Those are good numbers to have. What I needed was a good source, a price, and
a typical delivery. That tells me about when in my building process to invest
the capital in the prop. Do you by chance have a part number, or did they
quote solely based on diameter and pitch?
If that's the prop I think it is, it's the one AMD used on the FAR23 version
of the 601XL. In that case, it's a known good match to an O200. While I'm
building an experimental aircraft, I'd really like to limit the number of
things I'm experimenting with at any one time.
I'm surprised Sensenich's price is that low. I guess I'm accustomed to their
metal props, which sometimes ran in the $2,500-$3,000 range when I bought
them for relatively non-complex GA aircraft.
Thanks!
Jim B. Belcher
A&P/IA
