japhillipsga(at)aol.com Guest
Posted: Thu Oct 16, 2008 11:45 am Post subject: Misplaced Dimple Hole where Skin Stiffener SURFACE contacts |
Garey, sorry you messed up, but it won't be the last. I to have made a few extra holes and dimples. Unless it is structural what I did was install a short flush rivet and let it go. Sometimes you can make a bigger mess attempting to correct a flaw then just to plug and move on. There may be a "perfect" plane out there, but I doubt it. Good Luck, Bill of Georgia RV-8a finishing kit
| - The Matronics RV8-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Posted: Fri Oct 17, 2008 5:38 am Post subject: Misplaced Dimple Hole where Skin Stiffener SURFACE contacts |
Hi Garey-
I would have suggested to do as Bill did, and just put a flush rivet in the
extra hole. Having already oversized the hole, I'd recommend removing all
the cracked material, assembling the structure, and then filling the hole
with a dryish mix of epoxy / micro balloons. Properly filled and sanded,
you'll never be able to tell there was an 'oops' there.
glen matejcek
aerobubba(at)earthlink.net
Quote: | Subject: Misplaced Dimple Hole where Skin Stiffener SURFACE
contacts
Quote: | the Skin
Greetings:
Found no answer to this in Matronics archieves.
While dimpling the Elev Skin accidently punched a hole and made a dimple
about
Quote: | 1/8" from the desired location where the Skin Stiffener SURFACE MEETS THE
SKIN.
Quote: | (Stiffener was previously drilled / dimpled.) I "gently' flattened the
misplaced
Quote: | dimple with minimum thinning of the Skin - very slight dimple remains.
Then dimpled the desired rivet hole. The 2 dimples (desired and the
flattened
Quote: | undesired dimple) slightly over lap at their outer edges. Took a #49
drill and
Quote: | drilled the undesired dimple hole to relieve MOST of the Skin cracking at
the
Quote: | hole edges.
Question: Any suggestion on how to prevent possible "future" cracking of
the Skin
Quote: | where the undesired dimple is ?? Use RTV to fill the hole from the Bottom
Side and Super Fil to cosmetically fill in the Top Side of the Skin ??
(Do not
Quote: | believe RTV can be painted over - otherwise would use RTV on both sides
Quote: |
Appreciate suggestions, Garey
