europa(at)pstewart.f2s.co Guest
Posted: Fri Oct 17, 2008 1:17 am Post subject: connectors |
Anyone with nav/strobe units in wing tips - what have you used as
electical connectors at wing root. The ones I got supplied are VERY
heavy - looking for thoughts on anything more light weight.
Paul
G-GIDY
frans(at)paardnatuurlijk. Guest
Posted: Fri Oct 17, 2008 2:09 am Post subject: connectors |
Paul Stewart wrote:
You may want to look for "Molex" connectors. They are very lightweight
and easy to assemble. They are available in all sorts of different
amount of pins. Best known are the 4-pin ones that are used in the PC to
connect the power to the harddisks. For your purpose, you are going to
need 5 or 6 pin versions.
Otherwise take a look at eBay. I found a Bulgarian source for army stock
connectors. Very robust, with locking ring, high amp rating, and still
quite light weight and small. I use them because they have 20 pins, so
besides the nav/strobe it also connects the aileron trim, wing camera
mount, and on the ground this connector dual duties to make a connection
to the trailer (for ground power) to keep the batteries charged. It
saves me a separate connector, and make it impossible to forget to
disconnect before flight. The only downside is that the pins are
positioned very close together and are solder only.
Frans
acrojim7534(at)YAHOO.COM Guest
Posted: Fri Oct 17, 2008 3:53 am Post subject: connectors |
Paul
I used boat trailer connectors. They are flat 4 wire connectors.
Jim Brown
--- On Fri, 10/17/08, Paul Stewart <europa(at)pstewart.f2s.com> wrote:
[quote]From: Paul Stewart <europa(at)pstewart.f2s.com>
Subject: connectors
To: "europa-list(at)matronics.com" <europa-list(at)matronics.com>
Date: Friday, October 17, 2008, 9:16 AM
[quote]--> Europa-List message posted by: Paul Stewart <europa(at)pstewart.f2s.com> Anyone with nav/strobe units in wing tips - what have you used as electical connectors at wing root. The ones I got supplied are VERY heavy - looking for thoughts on anything more light weight. Regards Paul G-GIDY [quote][b]
steven.pitt2(at)ntlworld. Guest
Posted: Fri Oct 17, 2008 8:35 am Post subject: connectors |
I have used RS connectors - you can get them in 2,3,4 etc way www.rswww.com
ref 236-2984. Very light weight and inexpensive. I have my wing lights and
stall warner through each side and although they will not stand heavy
handling they are ideal for the connections - 2 1/2 years of derigging the
aircraft so far.
Steve Pitt
G-SMDH
Posted: Fri Oct 17, 2008 9:57 am Post subject: connectors |
Steve Pitt wrote:
www.rswww.com ref 236-2984. Very light weight and inexpensive.
These are the molex connectors I wrote about. I would use the 6-pin
versions for this purpose. 3 pins for the strobe, one for the shield,
and the two others for the nav lights. You could of course combine the
shield with the minus of the position lights, saving one pin, but this
might create radio interference. It is better not to share anything with
the strobe system.
Frans
Posted: Fri Oct 17, 2008 11:16 am Post subject: connectors |
Thanks for all the responses.
Getting dangerously close to running out of jobs(!!) after 10 1/2
years!!!
Paul
G-GIDY
lights and stall warner through each side and although they will not
stand heavy handling they are ideal for the connections - 2 1/2
years of derigging the aircraft so far.
Steve Pitt
G-SMDH
