rehn(at)rockisland.com Guest
Posted: Thu Oct 16, 2008 4:20 pm Post subject: Fuel drain kit |
I just got the fuel drain mod and was wondering from those that have gone before me if there are any little tricks or quirks to this install? Thanks
Jerry
914 Mono
air.guerner(at)orange.fr Guest
Posted: Fri Oct 17, 2008 1:50 am Post subject: Fuel drain kit |
Hello Jerry
The supplied drain kit (Mod 33) has one inconvenience: due to the length of the hoses from the tank to the drains, you must drain a lot of fuel before actually draining fuel from the bottom of the tank. One mod to the mod I made was to modify the fittings and use 4 millimeter hose instead of 8 mm. Therefore the dead volume is reduced by a factor 4 and the purging is more likely to be effective. Moreover, with the high fuel price we are experiencing now, there is some economic value to this change.
Remi Guerner
Posted: Fri Oct 17, 2008 6:39 am Post subject: Fuel drain kit |
Hi Gerry,
I recollect seeing an idea where folks had used the fuel tank outlets
that Graham Singleton used to fabricate and put the drains right at
the tank.
I have a question for the forum. Has anyone ever actually drained
water out of there tank? In the 4 years my aircraft has been flying I
have never seen a drop.
Cheers, Paul
Gary.Leinberger(at)miller Guest
Posted: Fri Oct 17, 2008 7:06 am Post subject: Fuel drain kit |
I have been flying for about 38 years - and always check my fuel for water - never found any - until last year once - so I keep checking.
Gary Leinberger
________________________________________
From: owner-europa-list-server(at)matronics.com [owner-europa-list-server(at)matronics.com] On Behalf Of Paul McAllister [paul.the.aviator(at)gmail.com]
Sent: Friday, October 17, 2008 10:37 AM
Subject: Re: Fuel drain kit
Hi Gerry,
the tank.
Cheers, Paul
Posted: Fri Oct 17, 2008 10:00 am Post subject: Fuel drain kit |
Paul
Thanks for the reply and I have never had water in 8 years. But our state is
now mandating 10% alcohol in our auto gas. I know alcohol attracts water so
I figured this may be another good reason to be concerned about water
showing up. Does that make sense? Just another precaution that I believe can
only help.
Jerry
Posted: Fri Oct 17, 2008 11:05 am Post subject: Fuel drain kit |
Hi! Gerry /Paul I had just a little once but just recently on return
from Europe I had some in the mini gascolator. However it was such a
struggle getting the bowl off I didn't get to see how much but just
where it had been because I spilt it all.
Just a word of warning to one and all ....do not get any fuel down your
ear it freezes the ear drum as it evapouates and creates an excruciating
pain.
Bob Harrison G-PTAG
Posted: Fri Oct 17, 2008 4:40 pm Post subject: Fuel drain kit |
to this change.
Remi Guerner
This is what I did, (if the picture comes through) The drain screws
into the AN914-1 fitting.
Graham
Description: |
Filesize: |
893.63 KB |
Viewed: |
165 Time(s) |
