ghinman(at)mts.net Guest
Posted: Wed Oct 15, 2008 11:42 am Post subject: Thin washers under bolts on gear tower |
I have the RV-8 QB
The quick builders put thin washers under the head of the bolts that
fasten the gear bolt weldment to the tower (see dwg 24 F802)
The drawing does not call for the washers,and it seems to make the AN3-5A
bolt too short. Can others with RV-8 QB check theirs and see if it the
same?
George H. Inman
ghinman(at)mts.net
Posted: Thu Oct 16, 2008 11:07 am Post subject: Thin washers under bolts on gear tower |
Hi George-
My copy of the plans calls for one normal thickness washer, and that's all
that's installed in my QB-8.
glen matejcek
aerobubba(at)earthlink.net
| Quote: | From: George Inman
Subject: Thin washers under bolts on gear tower
I have the RV-8 QB
AN3-5A
| Quote: | bolt too short. Can others with RV-8 QB check theirs and see if it the
same?
George H. Inman
ghinman(at)mts.net
