mauledriver(at)nc.rr.com Guest
Posted: Thu Oct 16, 2008 3:08 pm Post subject: Protecting fat wires from rear battery to firewall |
I'm installing a Z-14 dual batt/bus in an RV-10 with the battery and contactors in the rear. I have current limiters on the firewall between the alternators and the panel busses.
Should there be some protection in place for the fat wires running from the contactors in the rear and the firewall? Should I consider the ability to manually turn off the power through the contactors sufficient?
Thanks in advance all.
partner14
Posted: Thu Oct 16, 2008 3:25 pm Post subject: Protecting fat wires from rear battery to firewall |
I ran that cheap thin wall drip system black pipe the entire way. I kept my large wires seperate, the antenna wires seperate, and I think I used 2 more, one on each side, for everything else.
Don McDonald
--- On Thu, 10/16/08, mauledriver(at)nc.rr.com <mauledriver(at)nc.rr.com> wrote:
| Quote: | From: mauledriver(at)nc.rr.com <mauledriver(at)nc.rr.com>
Subject: Protecting fat wires from rear battery to firewall
Date: Thursday, October 16, 2008, 5:14 PM
| Quote: | --> RV10-List message posted by: <mauledriver(at)nc.rr.com>
40636 |
nukeflyboy
Joined: 05 Jan 2008 Posts: 162 Location: Granbury, TX
Posted: Thu Oct 16, 2008 5:18 pm Post subject: Re: Protecting fat wires from rear battery to firewall |
Because of the large starting currents (in excess of 200 amps) this is difficult to do effectively. These big wires are generally not fused. Use good quality terminations, torque them properly, make sure they are protected with bushings through each bulkhead, inspect them at the annual, then forget about it.
The wires that do not support the starter should be protected with a fuse or circuit breaker. But then, they are generally not big and fat.
Bob K talks about this in his book.
_________________ Dave Moore
RV-6 built and sold
RV-10 built and flying |
