jbhart(at)onlyinternet.ne Guest
Posted: Mon Oct 13, 2008 7:53 am Post subject: Alternative Tail Wheel Steering System |
At 07:09 AM 10/13/08 -0700, you wrote:
You say the "s" hook broke. Why did it break? I'm using the connector that
came with the compression springs from aircraft spruce, and I don't really
like the way it atttaches to the stock kolb tailwheel arm ( seems like a bad
wear point.)
Rob,
I had a similar problem with tension springs breaking and ground looping.
Came up with the following system. It may be of interest to you. See:
http://www.thirdshift.com/jack/firefly/firefly133.html
I have made a few changes since posting the above page. The spoke nuts are
shortened to save weight and round throttle stop collars are used to safety
the spoke nuts. I will be updating the page in the near future.
Jack B. Hart FF004
Winchester, IN
JetPilot
Posted: Mon Oct 13, 2008 8:11 am Post subject: Re: Alternative Tail Wheel Steering System |
Compression Springs also make tail wheel steering much more positive and precise. The centering actions of properly set up compression springs is much better than two springs in tension. I made the conversion on my MK III Xtra and it makes a huge difference in the way the plane handles on the ground.
Mike
Kolb MK-III Xtra, 912-S |
lcottrell
Posted: Mon Oct 13, 2008 3:34 pm Post subject: Alternative Tail Wheel Steering System |
Mike B:
I use compression springs also.
Wouldn't leave home without them.
[quote] Compression Springs also make tail wheel steering much more positive and precise. The centering actions of properly set up compression springs is much better than two springs in tension. I made the conversion on my MK III Xtra and it makes a huge difference in the way the plane handles on the ground.
Mike
barry9315
Posted: Wed Jul 23, 2014 9:32 am Post subject: Re: Alternative Tail Wheel Steering System |
Would love to see a few pics of the tail wheelcompression springs
Rex Rodebush
Joined: 10 Jan 2006 Posts: 209 Location: Branson West area, Missouri
Posted: Wed Jul 23, 2014 12:34 pm Post subject: Re: Alternative Tail Wheel Steering System |
I went to compression springs also but had to disassemble them and pinch the inside hooks to clear the spring I.D. so they would extend freely.
undoctor
Joined: 21 Oct 2008 Posts: 212 Location: Bethelhem, PA
Posted: Wed Jul 23, 2014 12:36 pm Post subject: Alternative Tail Wheel Steering System |
Hi Barry,
Here's a shot of the compression springs (other side is the same, of
course) on the FlagFly. Also shows a wider tail wheel to replace pizza
cutter.
Dave Kulp
Bethlehem, PA
11DMK
On 7/23/2014 1:32 PM, barry9315 wrote:
This email is free from viruses and malware because avast! Antivirus protection is active.
http://www.avast.com
167.33 KB |
8542 Time(s) |
Posted: Thu Jul 24, 2014 9:45 am Post subject: Alternative Tail Wheel Steering System |
Google tail wheel compression springs and hit photos.
Lake City, Colorado
_________________ John Hauck
Titus, Alabama |
ceengland7(at)gmail.com Guest
Posted: Thu Jul 24, 2014 5:08 pm Post subject: Alternative Tail Wheel Steering System |
Or, google 'screen door springs'. Much easier to find.
http://www.lowes.com/pd_192145-37672-543001_4294710978__?productId=3115801&Ns=p_product_qty_sales_dollar|1&pl=1¤tURL=%3FNs%3Dp_product_qty_sales_dollar%7C1&facetInfo=
Lake City, Colorado
