zenithlist(at)yahoo.com Guest
Posted: Sun Oct 05, 2008 7:16 am Post subject: Collins TDR-950 & Narco 500 Help |
I am looking for pinouts for Collins TDR-950 transponder & Narco 500 altitude encoder so I can connect them together. Does anyone have the pinouts?
| | - The Matronics Avionics-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Avionics-List |
hdwysong
Posted: Mon Oct 06, 2008 3:03 pm Post subject: Collins TDR-950 & Narco 500 Help |
| Quote: | I am looking for pinouts for Collins TDR-950 transponder & Narco 500 altitu
de encoder so I can connect them together.- Does anyone have the pinouts?
They're available on the AeroElectric site, John:
http://www.aeroelectric.com/Installation_Data/
See TDR950-950L.pdf and AR500-850.pdf.
dougritter(at)frontiernet Guest
Posted: Mon Oct 06, 2008 5:36 pm Post subject: Collins TDR-950 & Narco 500 Help |
Try the attached pinouts
Doug Ritter:
160.66 KB |
1104 Time(s) |
Posted: Sun Oct 12, 2008 8:06 am Post subject: Collins TDR-950 & Narco 500 Help |
Thank you all for pointing and providing info for the pinouts. I will make the wiring harness to connect the transponder & encoder next and powering on the devices. Beside sending these devices to avionic shop, are there any testing instructions on what to look for and to confirm they are working or not? I am somewhat knowledgable with electronics and have testing devices such as scope and frequency counter.
Vince Palermo
Posted: Sun Oct 12, 2008 8:26 am Post subject: Collins TDR-950 & Narco 500 Help |
Power up the system without the units plugged in and check the power and ground pins.
Vincent Palermo
vpalermo(at)tampabay.rr.com (vpalermo(at)tampabay.rr.com)
On Oct 12, 2008, at 12:04 PM, John Smith wrote:
[quote]Thank you all for pointing and providing info for the pinouts. I will make the wiring harness to connect the transponder & encoder next and powering on the devices. Beside sending these devices to avionic shop, are there any testing instructions on what to look for and to confirm they are working or not? I am somewhat knowledgable with electronics and have testing devices such as scope and frequency counter.
_________________ Vincent J. Palermo |
