bsallas(at)comcast.net Guest
Posted: Fri Oct 03, 2008 11:22 pm Post subject: 20 Amp Solid State Relay |
What is the status of AeroElectric's 20 amp solid state relay?
nuckolls.bob(at)cox.net Guest
Posted: Wed Oct 08, 2008 5:24 pm Post subject: 20 Amp Solid State Relay |
At 02:15 AM 10/4/2008 -0500, you wrote:
<bsallas(at)comcast.net>
The prototypes are laying on the assembly bench waiting
for the time to get them put together. Where were you planning
on using them?
( -Thomas Paine 1776- )
Posted: Thu Oct 09, 2008 5:14 am Post subject: 20 Amp Solid State Relay |
I was planning on using them for Master Battery Contactor, Starter
Contactor, Ground Power Relay, and Avionics Master Relay.
Posted: Thu Oct 09, 2008 9:13 am Post subject: 20 Amp Solid State Relay |
At 08:13 AM 10/9/2008 -0500, you wrote:
Hmmmm . . . I'm aware of no solid state contactor suited
for use as a battery master (high-current, bi-directional
capability). There are devices that could serve in the rest
of the applications you mentioned . . . but I'll suggest
your return on investment would be poor. All except the
Starter and Ground Power contactors good for hundreds
of amps are hefty devices with a commensurate price tag.
Our solid state relay will be a 20A rated device and could
be used for an AV Master relay but it's better suited to
pitot heater, landing lights, and perhaps a robust e-bus
alternate feed path.
