How big is the CH601HDS cockpit?
kevstewart
PostPosted: Thu Oct 09, 2008 1:40 am    Post subject: How big is the CH601HDS cockpit? Reply with quote
Hi All,
Having recently sold our PA38 we are looking for something newer and cheaper to run.
The CH601HDS looks a likely contender but there are none local to me that I can go and look at.
My question is: how much space is there in the cockpit? The reason I ask is that I am 6'4" and 190lb. My height is mainly biased towards my legs rather than my torso.
Do any of you guys have any experience of fitting someone my size into a 601? I see that there is a very useful diagram for the 601XL on the Zenair web site.
http://www.zenithair.com/zodiac/images/6-dim.gif
There is also a quote from a pilot:
"Just a quick note to let u know that I am 6'4" and weigh over 250 and I fit into the Super ZODIAC nicely. I encountered lots of headroom with the bubble canopy and was very surprised with the room." - TW
His quote mentions the Super Zodiac, does he mean the HDS variant or is he referring to the XL?
Some clarification/assistance would be much appreciated.
Many thanks,
Kevin (Plymouth, UK)
 Filesize:  4.48 KB
 Viewed:  6226 Time(s)
tshankland(at)sbcglobal.n
PostPosted: Thu Oct 09, 2008 5:36 am    Post subject: How big is the CH601HDS cockpit? Reply with quote
Kevin,
I am flying a 601HD, I am 6'3" tall and about 190 lbs. The trick is to have the rudder pedal placed as far away as possible. Also by varying the thickness of the seat cushion you can add more room. I built mine with the maximum leg room, rudders all the way forward and then made my seat cushions following instruction I found on line. The first thing I found when I put it all together in the plane was that my head (headset) tended to hit the canopy. I took about two inches of padding out of the bottom of the pilots seat. That took care of that. Later I felt that I needed more leg room and I removed a 1 inch peace of foam from the seat back. There is still plenty of foam and I can easily fit in the cockpit.
Tim Shankland
601HD N707TS
kevstewart wrote:
Hi All,
Many thanks,
http://forums.matronics.com/viewtopic.php?p 8021#208021
http://forums.matronics.com//files/6_dim_821.gif
bryanmmartin
PostPosted: Thu Oct 09, 2008 6:13 am    Post subject: How big is the CH601HDS cockpit? Reply with quote
Also the seat pan itself can be installed a bit lower than the plans show. I think mine still has at least an inch between the seat and the bottom of the fuselage.
Bryan Martin
do not archive.
kevstewart
PostPosted: Thu Oct 09, 2008 12:13 pm    Post subject: Re: How big is the CH601HDS cockpit? Reply with quote
Thanks guys. I am hoping to take a look at a 601HDS that is for sale in the UK. Weather permitting I might be able to see it next week.
How easy is it to adjust the rudder pedal position?
Kevin
Recreational pilot flying out of
EGHD Plymouth, UK.
n601xs(at)gmail.com
PostPosted: Fri Oct 10, 2008 7:19 am    Post subject: How big is the CH601HDS cockpit? Reply with quote
Kevin,
The rudder pedal position is mostly a function of the length of the cables. I found an easier solution lengthening an aileron cable by replacing the standard turnbuckle with long one. The long turnbuckles, available from ACS are 1-3/4" longer than the standard. Given the geometry of the rudder pedals that would move the pedals ~ 3" closer to the firewall.
Craig S.
N601XS
On Thu, Oct 9, 2008 at 3:13 PM, kevstewart <kevin(at)kevstewart.freeserve.co.uk (kevin(at)kevstewart.freeserve.co.uk)> wrote:
[quote]--> Zenith-List message posted by: "kevstewart" <kevin(at)kevstewart.freeserve.co.uk (kevin(at)kevstewart.freeserve.co.uk)>
Kevin
EGHD Plymouth, UK.
[url=http://forums.matronics.com/viewtopic.php?p 8090#208090]http://forums.matronics.com/viewtopic.php?p 8090#208090[/url]
Gig Giacona
PostPosted: Fri Oct 10, 2008 8:46 am    Post subject: Re: How big is the CH601HDS cockpit? Reply with quote
Don't forget the nose wheel steering rods will have to shortened as well.
W.R. "Gig" Giacona
601XL Under Construction
