Throttle springs
Jim Feldmann
PostPosted: Wed Oct 08, 2008 9:29 am    Post subject: Throttle springs Reply with quote
Hi:
I'm new here, having just purchased a Kitfox IV Speedster with a Rotax 912UL.
The throttle springs are set to open the throttle in the event of a linkage failure. OK, but the springs are so strong that they pull the cable right past the ratchet in a vernier throttle. I'm using a collet type throttle, but as soon as I loosen the collet, the springs try to pull the throttle out of my hand.
Is there a lighter spring available? What have you done and where did you get the springs?
Jim Feldmann
Kitfox IV Speedster
912UL N629JB
rlborger(at)mac.com
PostPosted: Wed Oct 08, 2008 9:46 am    Post subject: Throttle springs Reply with quote
Jim,
I don't have a Kitfox (darn nice airplanes, BTW), I have a Europa. But, I'd replace the throttle linkage system before I'd replace the throttle springs. Find a throttle handle/linkage with adjustable friction.
Just my 2 cents. I'm sure there will be opposing suggestions.
Bob Borger
Europa XS Monowheel, Standard Wings, Intercooled Rotax 914, Airmaster C/S prop.
99.9% complete. Chasing gremlins in the audio panel wiring.
http://www.europaowners.org/N914XL
On Wednesday, October 08, 2008, at 12:29PM, "Jim Feldmann" <feldesign(at)earthlink.net> wrote:
Hi:
Jim Feldmann
Kitfox IV Speedster
912UL N629JB
http://forums.matronics.com/viewtopic.php?p 7924#207924
Jim Feldmann
PostPosted: Wed Oct 08, 2008 2:40 pm    Post subject: Re: Throttle springs Reply with quote
Just got back from the hanger and I took a picture of the linkage I am talking about. It seems like that is an awful lot of spring just to open the throttle in case of a linkage failure. Not sure I would like to see what happens if the linkage only fails on one side either.
The main problems though are the difficulty in holding a specific throttle setting during approach, and the fact that the throttle creeps open during cruise.
Jim
This is the right carb. The left is the same.
 Filesize:  632.69 KB
 Viewed:  444 Time(s)
joeing701(at)internet.is
PostPosted: Wed Oct 08, 2008 2:46 pm    Post subject: Throttle springs Reply with quote
Hello Jim.
I am flying a Zenith 701 with the same engine. Please never change the
springs in the carb linkage. It could lead to a major engine power
loss in a situation when you really need the fast reaction from the
carbs.
This accident is the direct cause to the change of throttle linkage
springs. See the link.
http://www.ch601.org/stories/croke_crash.htm
I am using a Vernier throttle cable in my plane with friction lock.
It works great and I never have any problems with the spring wanting
to pull the throttle lever in. I even have another on the right side
but always make sure that the friction lock on that side is loose.
Hope this helps in your decision making.
Best regards,
Johann G.
Hi:
Rotax 912UL.
Jim Feldmann
Kitfox IV Speedster
912UL N629JB
 Filesize:  107.38 KB
 Viewed:  422 Time(s)
daberti(at)sbcglobal.net
PostPosted: Wed Oct 08, 2008 2:58 pm    Post subject: Throttle springs Reply with quote
Search the Zenith archives for Jon Croke...changing those springs cost him
his 701! Need I say more?
PostPosted: Wed Oct 08, 2008 3:02 pm    Post subject: Throttle springs Reply with quote
Hello Jim.
I just looked at the spring in your throttle linkage and it looks to
me that this is not the original Rotax part. I would order new springs
from a Rotax dealer and see if that does not change the situation.
They look more bulk than the original and also the ones I am using
have a long straight neck on one end. Take a look.
Top left of photo. Hope you can see the long straight end of the spring.
Johann G.
Jim
http://forums.matronics.com/viewtopic.php?p 7971#207971
http://forums.matronics.com//files/dscf1265_121.jpg
 Filesize:  140.81 KB
 Viewed:  444 Time(s)
Jim Feldmann
PostPosted: Wed Oct 08, 2008 3:11 pm    Post subject: Re: Throttle springs Reply with quote
Thanks guys. I went to the Croke 701crash posting, and it appears that his original springs have a long end also. So it looks like mine have been replaced.
I will contact Rotax.
Jim
larry(at)macsmachine.com
PostPosted: Wed Oct 08, 2008 4:24 pm    Post subject: Throttle springs Reply with quote
Jim,
The spring throttle combination is not a good one. I recommend you
remove the springs, find a linkage to tie the two carbs together and go
with a solid
wire as do the regular aircraft manufacturer's products. It takes a bit
of thought, but it does work. I did this in my Subaru with two Bings
and I've had no
problems with the system. Pulling out the cable and replacing it with a
1/16th diameter music wire in the cable casing is the beginning and it
will not bend
in the length of free throw the Bing carb linkage requires, especially
without the springs. See links
http://www.macsmachine.com/images/controllinkages/full/throttlewire.gif
http://www.macsmachine.com/images/controllinkages/full/abinghardcablelink.gif
http://www.macsmachine.com/images/controllinkages/full/throttlelink.gif
Realizing the Rotax doesn't have much if any direct access for linkage
between the carbs, but the person that solves that problem will have
solved a serious
deficiency in the current design.
Best regards,
Jim
Roger Lee
PostPosted: Wed Oct 08, 2008 7:42 pm    Post subject: Re: Throttle springs Reply with quote
Hi Jim,
Those are not Rotax springs. Order some new carb linkage springs and enricher /choke springs. The new springs are lighter than what you have. Don't get caught up in the good ol'e boy way of fixing your engine. There is a reason and usually a very well tested reason that Rotax does things a certain way. You thought enough to buy a plane and you want it to keep you in the air without facing any problems now or down the road. Maintain it with the same fore thought.
The push / pull type of throttle will work. Just make sure you use the correct wire and throttle.
Enjoy your plane and your flights.
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
Thom Riddle
PostPosted: Thu Oct 09, 2008 3:47 am    Post subject: Re: Throttle springs Reply with quote
That picture says it all. That throttle return spring looks a lot like the carb support spring just above it, and as Roger said, that is definitely the wrong spring.
Our RANS S6 has a Vernier throttle with correct Bing throttle return springs and that combination works as designed.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Jim Feldmann
PostPosted: Thu Oct 09, 2008 7:28 am    Post subject: Re: Throttle springs Reply with quote
Thank you all for your help. I will order the correct throttle and choke springs from Rotax.
Jim
Dick Maddux
PostPosted: Fri Oct 10, 2008 4:07 am    Post subject: Throttle springs Reply with quote
Jim,
Those are not the correct springs for the engine.They look home made.Get in touch with Lockwood or another vendor to get the correct springs. I had the same problem with my Kitfox and went from the friction throttle to the Vernier (new) from Spruce. I can now dial in my throttle settings. I takes some practice but it works well.
      Dick Maddux
      Kitfox4-1200
      Pensacola,Fl
New MapQuest Local shows what's happening at your destination. Dining, Movies, Events, News & more. Try it out!
Jim Feldmann
PostPosted: Wed Oct 15, 2008 2:41 pm    Post subject: Re: Throttle springs Reply with quote
I bought the correct springs from Rotax and installed them. Problem solved.
Thanks to all for your input.
Jim
