jbowerman(at)fastspot.net Guest
Posted: Thu Mar 16, 2006 7:41 am Post subject: New purchase |
All,
I may be purchasing a CJ-6A in the next few days and would like some advice on how to file with my local FSDO. I know there has to be a program letter, but don’t know the best way to write it. Any advice would be greatly appreciated.
Jim Bowerman
flushjohnson(at)charter.n Guest
Posted: Sun Mar 19, 2006 10:57 am Post subject: New purchase |
BE CAREFUL WITH THE FSDO! Check the air worthiness certificate and log books for original issue date. If the airplane is pre-moritorium they might tell you that a new AWC will have to be issued. If this happens the airplane will have to be operated under the newer rules. There is incorrect. There is an owner here in the DFW area this happened to and he is having hell getting it steaightened out.The original AWS is good regardless how many people have owned it.
Posted: Sun Mar 19, 2006 2:42 pm Post subject: New purchase |
<The original AWS is good regardless how many people have owned it.> That is true provided it is a premoratorium aircraft. If it is a post moratorium aircraft, the airworthiness certificate is reissued when the airplane is sold or is moved to a different home base airport as listed in the aircraft's Operating Limitations because the OL's and AWC are married together. Unfortunately, a FSDO can choose to rewrite the OL's based on the current regulations/FAA Order covering the operation of the aircraft.
Dennis
Scooter
Posted: Sun Mar 19, 2006 4:40 pm Post subject: Re: New purchase |
You might also need a ferry permit to get it to your new home base. I had to do this and neglected to get a mechanic's sign-off and caught some flack from my local fsdo. Why did I need a mechanic's sign-off? Because it was on the ferry permit form (I guess).
My local fsdo "helped" me rewrite the airworthiness certificate and operating limitations. They also gave me crap about my airspeed indicator being in KPH (which apparently are not "English" - per the regulations). Hmm...
My advice when dealing with the fsdo on this: smile, nod your head, don't volunteer any information and try not to strangle anyone.
Posted: Sun Mar 19, 2006 5:22 pm Post subject: New purchase |
Scooter,
You have definitely got it figured out! These FSDO guys sometimes don't
have a clue as to how or what to do. With regards to having to get a ferry
permit, maybe it's true that an A&P has to sign one off. A ferry permit is
issued to ferry an aircraft from point A to point B when it is by definition
"unairworthy". ie: out of annual etc? Not to relocate an airplane to
another home base airport. FWIW, See part 21.197
http://www.airweb.faa.gov/REGULATORY_AND_GUIDANCE_LIBRARY/RGFAR.NSF/0/A86F3EF7C96B5C46862570EC0077E295?OpenDocument.
I'm sure your airplane was in annual.
Dennis
Posted: Sun Mar 19, 2006 5:36 pm Post subject: New Purchase |
Scooter,
Dennis
Posted: Sun Mar 19, 2006 5:54 pm Post subject: New purchase |
The airplane in the DFW area was orig. certificated and registered in 1991- pre-moritorium. Some previous owner allowed the FSDO to issue new AWC and OL's not realizing this was incorrect. Probably can't be undone , but trying. This plane was owned by BARRY HANCOCK . Any info or history would be helpful. I will pass on to owner.---
Posted: Sun Mar 19, 2006 6:06 pm Post subject: New purchase |
I seriously doubt there is anything that can be done to put it back as a premoratorium aircraft. You may want to talk with the EAA/Warbirds of America government affairs group. Explain the situation and get their advice. It's probably too late though.
The key is a FSDO can choose to rewrite the OL's based on current regulations/FAA Order 8130.2x. That's tough to challenge and win.
Dennis
Scooter
Posted: Sun Mar 19, 2006 7:41 pm Post subject: Re: New purchase |
I don't recall now why I needed the ferry permit. Must have been because the airworthiness certificate was no longer considered valid (because I was buying the airplane and moving it away from its home base). I contacted the fsdo where the aircraft was based and my local fsdo. Seems like my local fsdo thought i needed the ferry permit but the other fsdo didn't. But I can't recall now.
It's a hell of a thing to sit there in your fsdo guys office and have him tell you that you just busted the regs. Then after you've exhausted your arguments to no avail he tells you that he just wants to point that out for your benefit. Your balls are in his hands and its a real helpless feeling.
dsavarese(at)elmore.rr.co wrote: | Scooter,
have a clue as to how or what to do. With regards to having to get a --- |
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Sun Mar 19, 2006 9:33 pm Post subject: New purchase |
Scooter wrote:
No, there was no need to do anything besides have the previous owner
send a FAX to the local FSDO saying that the bird was flying to your new
home.
Most of the problems crop up when people start trying to analyze and
second-guess the rules and regs. And the guys at the FAA probably
understand those rules no better than you do.
Sure you need to change the AC and the LOL *when* *you* *change* *the*
*aircraft's* *home* *base*. But when you buy the aircraft and fly it
home, its home base is still its old home base and the AC and existing
LOL are still valid. Changing the registration does not invalidate the
AC and LOL unless the existing LOL says that it does. I have never seen
an LOL that does but am prepared to be enlightened.
So why do you want to change the LOL and AC? Because you want to be able
to fly the airplane for proficiency within the 300nm radius of your
airport AND the airplane is going to reside withing the jurisdiction of
the new FSDO. But until you do that, you send a fax to the old FSDO and
then fly away. The airplane is flying to its new home temporarily and
the old FSDO is still the authoritative office. No ferry permit needed.
So, fly it to its new home and then go visit the new FSDO with the old
AC and LOL in hand. Carry your new program letter with you. If you make
an appointment ahead of time you should be out of there in about 15 minutes.
Quote: | I contacted the fsdo where the aircraft was based and my local fsdo. Seems like my local fsdo thought i needed the ferry permit but the other fsdo didn't.
That is because you made the mistake of asking the question. Remember,
if you ask a question be prepared to be instructed that you may not do
what you want to do. The most restrictive answer is also the safest for
the FAA employee answering your question.
Brian Lloyd 361 Catterline Way
brian-yak at lloyd dot com Folsom, CA 95630
- Antoine de Saint-Exupery
_________________ Brian Lloyd
- Antoine de Saint-Exupery |
Scooter
Posted: Mon Mar 20, 2006 10:04 am Post subject: Re: New purchase |
Actually I believe I was just calling the fsdo to work out the details on my new required paperwork. They asked the right questions and determined that I was ferrying the aircraft without a permit. What followed was a very heated telephone conversation.
Had I flown it w/o the permit then walked in to their office and told them the truth then my nuts really would have been in the fire. It's probably legal w/o the ferry permit but i'd have to convince them of that.
My advice is: do it their way no matter how stupid it is. This avoids any potential conflict. Remember you are guilty until proven otherwise.
home.
wade154(at)frontiernet.ne Guest
Posted: Mon Mar 20, 2006 2:17 pm Post subject: New purchase |
Hi all I was curious about the operating limitations for an aircraft that
I'm trying to sell got most of my answers at
www.utility-aircraft.com/catalog/certificate/order.htm the aircraft that I'm
selling had a paragraph stating that if it was equipped to operate night
and/or IFR it could be done, but when asked to come into the local FSDO they
changed it to VFR-DAY only. How many aircraft with OL can be operated
IFR-NIGHT?
Bill Wade
N4450Y
gus.fraser(at)gs.com Guest
Posted: Mon Mar 20, 2006 2:41 pm Post subject: New purchase |
I think your FSDO is behaving badly !
8130.F is the smorgus board of regulations from which the FSDO will select
and include paragraphs, pretty much verbatim, into your OP lim letter. The
section that deals with lights, night and IFR reads as follows
(13) Unless appropriately equipped for night and/or instrument flight in
accordance with 91.205, this aircraft is to be operated under VFR, day only.
See the point here is that the FSDO is supposed to select from the menu,
there should be no ala carte option.
If I were you Bill I would challenge them on it. If they still refuse to see
the light set EAA on them those government affairs guys just love a good
scrap with the feds.
Best of luck with that.
Gus
L39parts(at)hotmail.com Guest
Posted: Mon Mar 20, 2006 4:28 pm Post subject: New purchase |
All of them, except yours. You got screwed for being gullible.
shinden33(at)earthlink.ne Guest
Posted: Mon Mar 20, 2006 5:53 pm Post subject: New purchase |
Scooter,
I would have to disagree with regards to arguing. The more we let them get
away with the more lax and criminal they will get. 90% of the government
agencies and workers I have dealt with are nothing more than jobs programs
(hence one of the main reasons I am leaving my current job as a DOD
civilian). These people must be kept in check to the best of our ability
or they will end up making life harder on everyone. Believe me, I
understand how difficult it is to do so but they are not the Gods they think
they are. One on one they will scorn you. Bring up the regs in more public
forum or to their superiors (at whatever level you need to go to) and you
will find generally they back down.
Scott
Posted: Mon Mar 20, 2006 8:11 pm Post subject: New purchase |
Each paragraph from the smorgus board you speak of has specific group
applicability. Some say "All", others say Group III under 800 horsepower
(our aircraft), etc.
Dennis
brian
Posted: Mon Mar 20, 2006 8:33 pm Post subject: New purchase |
Scooter wrote:
No, you need a ferry permit to operate an aircraft that does not have a
valid airworthiness certificate. The airplane had a valid airworthiness
certificate. You did not need a ferry permit.
The airworthiness certificate is NOT tied to the aircraft registration.
They are separate and disconnected.
Quote: | Had I flown it w/o the permit then walked in to their office and told them the truth then my nuts really would have been in the fire. It's probably legal w/o the ferry permit but i'd have to convince them of that.
No, you don't have to convince them of anything. You just tell them that
you are changing the aircraft's home base to a new field that happens to
be within their jurisdiction. Until they issue a the AC with a new LOL
indicating the new home field, you are operating on a valid AC whose LOL
indicates a different home field that falls within the jurisdiction of a
different FSDO. No rocket science here.
Quote: | My advice is: do it their way no matter how stupid it is. This avoids any potential conflict. Remember you are guilty until proven otherwise.
You are doing it their way. They wrote the regs and you are adhering to
them. You just aren't doing it the made-up way that some bonehead came
up with on-the-fly at your local FSDO when you happened to call on the
phone. Big difference.
Posted: Mon Mar 20, 2006 8:58 pm Post subject: New purchase |
If you have moved to a new address along with moving your airplane to a new
home base airport within the same FSDO's jurisdicton, you must first obtain
a new registration with your new address before the FSDO will issue a new
airworthiness certificate and OL's. That means you must present your new,
hard copy registration to the FAA inspector. He can't issue a new AC and
OL's without physically see it.
Dennis
Scooter
Posted: Tue Mar 21, 2006 4:24 am Post subject: Re: New purchase |
I think you're missing the point Brian. I knew/know I was correct - hence the argument with the fsdo. If you guys want to fight the government then have at it! I've done my fighting.
